Putting your car on ramps can damage your concrete??
Discussion in 'Gen 2 Prius Main Forum' started by Horseflesh, Mar 3, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,639
    788
    Southern California
    Full ramps are not needed to get to the front lift point with a floor jack. I have used some scrap 10x2 lumber pieces for this purpose. Run the car up on those, slide the floor jack underneath, center it on the lift point (somewhat difficult, helps to have another person spotting from the side), then crank it up. The first couple of cranks there will barely be room to move the lever on the floor jack, but after that it is smooth sailing. My floor jack can actually fit underneath without putting the car up on anything, but there isn't enough clearance to move the lever arm. It is a HF Pittsburgh 3 ton low profile floor jack. Had it for years, not sure if the current one by the same name will still fit.
  2. Mendel Leisk
    41,463
    In particular, gen 2 and gen 4 (not sure about gen 5), have front jacking point that's way back, more-or-less in line with the front wheels. Even if you can get the jack to it, it's dicey if there's enough clearance to get it started; jack handle bangs the underside first. For that low-rise ramps may help; just 3~4 inches should be enough. Relatively easy to cobble, say out of 2x8 on the flat. I made some with 2x4 on edge, effective, but maybe overly complicated.
    I'm using a venerable Sonoma 3 ton jack, an older design I think (purchased 2005), the jack handle starts pumping practically horizontal, and it isn't constantly trying to spring up to vertical. Got it for $69 CDN, on a snowy Boxing Day.
    (Gen 3 front jacking point is a walk-in-the-park: back about 15" from face of front bumper. One plus...)
    #22 Mendel Leisk, Mar 5, 2025
  3. Horseflesh
    Horseflesh Junior Member
    30
    Pacific Northwest
    Thanks again for everyone's help. I have ramps & chocks & other tools and supplies on the way. We'll do the first oil change next week. I'm going to use Costco 5W-30 synthetic, reviews seem to put it on par with Mobil 1 and it's about half the price. Cost of a change with a Toyota filter will be about $30.
  4. Mendel Leisk
    41,463
    I was using bulk Toyota 0W20, brought a container to dealership, was very inexpensive, till suddenly, it wasn't. After that fell through I settled on Costco's Kirkland brand motor oil. Everyday low price, what's not to like. Just yesterday noticed this video, comparing to Mobil 1, favourably, and cheaper:
    The middle of the video goes on and on, I slept through most of it, lol.
  5. Prodigyplace
    12,564
    11,779
    Central Virginia
    Is the Costco oil really that much cheaper than the Mobil 1 jug from Walmart? At ,east at one time I thought Mobil made the Toyota oil anyway,
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,465
    2,429
    Taylors, SC
    Walmart Super Tech motor oil from Warren Distribution is made by various suppliers.
    If the bottle has the same large size cap and neck as the Mobil 1 bottle, it is made and filled on the same assembly line as Mobil 1.
  7. Horseflesh
    30
    Pacific Northwest
    There is no Walmart near me so I never price check there. But at Costco, Mobil 1 is about $6.70/qt and the Kirkland Signature version is $3.60/qt.
  8. Prodigyplace
    12,564
    11,779
    Central Virginia
    5 quarts for $28
    Horseflesh likes this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    10,155
    6,313
    Texas Hill Country
    This recent video from a guy with Nascar oil analysis experience picked $4 a quart Napa oil over Walmart, Royal Purple or Amsoil.
    Ramps:
    The real danger with ramps is cheap built units collapsing. Same goes for cheap jack stands. I think your friend heard one of those stories and did not get it.
    Prodigyplace likes this.
  10. pasadena_commut
    2,639
    788
    Southern California
    Which is why one should always put extra incompressible objects under the vehicle in appropriate places to support it and protect the person working underneath. See the image in this post:
    Modifying ramps for DIY maintenance on Prius? | PriusChat
  11. Horseflesh
    30
    Pacific Northwest
    I'd like you all to know that I changed my oil with RhinoRamps, without getting a concrete test first, and everything worked out OK.
    Thanks to everyone here, and everyone else who has made excellent information about this car available over the years.
    mr_guy_mann, Prodigyplace and dolj like this.
  12. Aegean
    Aegean Active Member
    463
    208
    Alexandria VA
    Residential slab concrete has strength of 2500-3000 pounds per square inch. In other words you can put the whole Prius weight on a square inch metal rod trying to penetrate the concrete floor and still it will not be damaged.
  13. pasadena_commut
    2,639
    788
    Southern California
    The floor should not be damaged as long the floor is completely flat and the 1 sq in support rod is absolutely vertical while the load is slowly lowered onto it. (Also assuming there are no defects in the cement and no voids below it.) If the rod is tilted even a little the force will be much higher at the lowest edge. It probably won't punch through the slab, or even penetrate very far at all, just enough to get the entire bottom in contact with the surface, but it will probably chip the surface. (That is basically a chisel, albeit a poorly designed one.) If the floor isn't flat to start with the area underneath the rod will be flattened to some extent as the high points initially take all of that weight over a tiny area, putting them way past their 3000 psi rating, so that they crumble.
