PVC Valve Location
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pfarah, Apr 18, 2015.
  1. pfarah
    pfarah Junior Member
    Hello out there!
    My first post but have been a member for some time. I have a 2010 Prius with 104k miles and I just replaced the spark plugs today. As soon as I put everything back together and gave her a test run, I remembered the PCV valve...
    My question is, where exactly is it and would someone please post a pic? I'm heading to the dealer tomorrow AM (They're open on Sundays from 9-1) to pick one up. Removing all the covers, cowling, etc. isn't too bad (about 10 minutes now that I know what I'm doing). Thanks in advance!
    Patrick
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Here's the manual for it.
  3. Fishcrab
    Fishcrab Member
    152
    29
    Fro doz,
    Little off subject but can you post something ,maybe an attached file, on a new thread ,how to get into the HV fan assy to clean it out on a gen 2. Thanks
  4. frodoz737
    4,297
    2,348
    33
    Sorry...I do have the GEN II Service Manual currently loaded. While I do have the GEN III material (which is likely similar), someone else might better provide the specifics you need for your application.
  5. Mendel Leisk
    38,729
    Just diving in is probably as good a course as any. You'll likely have to pull up the hatch floor. If it's like 3rd gen, there's some tenacious fasteners. Makes you think you've missed a bolt or something.
  6. Fishcrab
    Fishcrab Member
    152
    29
    Will explore utube more too, mine is a gen 2.
    Maybe I will download manual, where should I look for it?
  7. PlumbersCrack
    PlumbersCrack Junior Member
    45
    2014 Prius Plug-in
    OR - remove the under body and remove it like that. I removed the plastic from under, unclipped the hose with my finger and used a wrench to remove it. Took about 10 minutes total time.
  8. Fishcrab
    Fishcrab Member
    152
    29
    Thanks, So your talking about under the HV fan, inside the cars cargo backseat area?
  9. ChapmanF
    15,640
    Judging by the content, I think that was from a poster who paid too much attention to the thread title and thought it was still about the PCV valve. :)
    As far as the service manual, the sure-fire place to look is techinfo.toyota.com.
    -Chap
    Fishcrab likes this.
  10. Fishcrab
    Fishcrab Member
    152
    29
    thanks Chap, bet ur right, thought I had an easy way out for a second... :)
  11. JC91006
    16,482
    8,400
    Watch this video on taking out a HV battery, it'll show you how to take everything out........if you are just doing the fan, just do the right half of the car and do not continue to anything else. You should have all your information before the 5:00 mark of the video.
    #11 JC91006, May 11, 2015
  12. frodoz737
    4,297
    2,348
    33
  13. Mendel Leisk
    38,729
    The car itself is not a bad teacher, too. If you just take it slow and logical, keep your parts sorted, you'll get there.
  14. PlumbersCrack
    45
    2014 Prius Plug-in
    My response was to the actual PCV in the engine bay, not to anything doing with the rear of the vehicle.
