  1. Zaza 13
    Zaza 13 Junior Member
    74
    Israel
    Today my friend bought prius gen 3, 100k miles car, I was very surprised there is no difference if pwr mode is on or not, car doesnot reacts on pushing differently. What can it be?
    #1 Zaza 13, Dec 25, 2018
  2. Tariq87
    Tariq87 Member
    87
    28
    jordan
    How old is the car?
    And you must check hybrid battery..
    What is the voltages for each cell
    Zaza 13 likes this.
  3. Zaza 13
    74
    Israel
    Car is 2009, with new battery 1 year old, I checked toyota dealers history, and in past there was problem with inventer, but last checking was good, its very strange, I have 2012 prius with 225k miles, also with new battery 2 years old, and i feel 2x power on my car. Maybe there is some problem with ecu
  4. mjoo
    mjoo Senior Member
    1,127
    1,317
    Michigan
    Check the EGR
    Pixel XL ?
    Zaza 13 likes this.
  5. Mendel Leisk
    38,729
    I wonder if the Original Poster's "2009" is third or second gen? Around the world the descriptions vary? In North America there were 3rd gen "2010's" with 2009 build-dates. If it's in fact second gen there's no EGR.
    Does Original Poster's problem car have body coloured or piano-black tail scoop (aka wind fairing). The latter would be 3rd gen, the former is second gen.
    This is 3rd gen engine bay, EGR valve at centre of picture:
    #5 Mendel Leisk, Dec 25, 2018
    mjoo likes this.
  6. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Let me tell you about my car because im facing this issue with my 2010 ..
    I check the EGR pipe and cleaned all intake manifold and EGR coolant and cleaned MAF sensor and put new sparks...same issue still exists but there is some weakness in hybrid battery and also there is hesitation in acceleration...i think these kind of issues will not be solved just by replacing replace the HV battery..
    Zaza 13 likes this.
  7. Zaza 13
    74
    Israel
    I dont think that there is egr problem, car is after toyota dealer checking, if there was egr problem they could solve it.
  8. Zaza 13
    74
    Israel
    In Israel there are the both models also gen 2 also gen 3 built in 2009.
    Tariq87 and Mendel Leisk like this.
  9. Zaza 13
    74
    Israel
    I think there is some problem in "chip", which controls how much gas and electric power give to make proper acceleration, everyone knows if car runs on normal mode and driver dicedes to turn on pwr mode it takes lets say at least 1,5 sec, this car doesnot reacts at all, there is no difference which mode car works the same power, sometimes prius with this pause gives filling of turbo diesel car, which has to wake up and make it self to move. my cars eco mode is more effective and powerful (225k miles) then my friends (100k miles).
  10. Zaza 13
    74
    Israel
    Car is 2009 gen 3, japanes. Maybe in U.S.A toyota started building from 2010?!
  11. mjoo
    mjoo Senior Member
    1,127
    1,317
    Michigan
    Let us know if they fix it. That would be big news
    Pixel XL ?
    Raytheeagle likes this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I’m not holding my breath:oops:.
    mjoo likes this.
  13. Mendel Leisk
    38,729
    Just for the record: ECO, Normal and PWR modes only change the gas pedal travel rate. PWR mode for example, does not give the engine any more power; it just reduces the pedal travel needed.
    Pluggo, jerrymildred and Raytheeagle like this.
  14. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Every time I see PWR mode I get the Top Gear fellows voices in my head:
    “More PWR”:ROFLMAO::ROFLMAO::ROFLMAO:.
    I just drive it(y).
  15. bisco
    49,500
    probably just a bad switch
  16. Mendel Leisk
    38,729
    That's really the low hanging fruit, easiest thing to check. Oh: does the dash display the "PWR" light when you push that button?
    And if that's all it is, I wouldn't be in a rush to fix it: Normal mode (no buttons pushed) is very linear feel.
  17. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    The only one that doesn’t display is normal mode;).
    So the switch could be the culprit or if in another mode, does the display change?
  18. Mendel Leisk
    38,729
    It's been a long time since I've used anything but "normal" (years, except when buttons accidentally pushed), but I'm sure both ECO and PWR display text icons when on.
  19. Zaza 13
    74
    Israel
    Yes, it's visible on dash, and from my expirience power mode lets engine to work on max output, but in eco mode I dont feel it, like I feel that there is more rmp.
  20. Zaza 13
    74
    Israel
    Egr
    Egr is ok
