Qi wireless charging and phone case thickness.
Discussion in 'Gen 4 Prius Main Forum' started by Ben Little, Dec 10, 2016.
  1. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Inverse square law. The field is reduced by the square of the distance. Double the distance, the field drops to 1/4. The sad truth of electromagnetic fields. ;)
    I think your best bet is a proper cig. lighter phone charger. It's really the only way you can get the current you need on the USB micro connector, and is really necessary if you have USB C (Oneplus 3T, Pixel, etc).
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Can't argue with your science, but my Nexus 6 (6" phablet) always charges quickest on the Qi charger pad than using a 2amp USB cable from the power socket. Although the phone has a curved back wall I've stuck 3 little neoprene studs either side of the pad and that anchors it in nicely, stopping any rocking from side to side.
  3. deathmage
    deathmage Junior Member
    Los Angeles ca
    I too have an s6 with otterbox and i have to mess with the position to get a connection. I'm thinking of a clear case hoping that it'll work better
