Quantitative Results of Grid Charge/Discharge
Discussion in 'Gen 2 Prius Technical Discussion' started by S Keith, Dec 6, 2015.
  1. jeff652
    jeff652 Senior Member
    607
    623
    Idaho
    I should correct myself. I was wrong in my prior post. The shipping cost to Canada for the *Prius* package is/was $65. The reason for this is the two-bulb discharger required that we use a 12x12x6 6lb or larger box. We have been using the Priority Mail large flat rate boxes. These do in fact cost $65 to Canada. However, I just investigated the Priority Mail Regional Rate B box with a 6 lb weight and the shipping on those is around $45! That is very cool. Thanks for pointing this out and helping prod me to explore other options. I am editing our shipping tables to adjust the shipping costs down right now :)
    m.wynn likes this.
  2. stephane
    stephane Prius v owner
    120
    64
    Quebec Canada
    2013 Prius v wagon
    Getting better Jeff just to help you more im sure if you search you could even get better 12x12x6 6lb is a very small box and should be able to get rate as low as 25$.
  3. Iamjo20
    Iamjo20 Member
    259
    This is truly interesting to me! However, I know I cannot do this test/charge/discharge--who typically does something like this? TY
  4. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Buy yourself a MiniVCI for about $30, and you suddenly have the ability.
    EDIT: and a 32bit WinXp or Win7 laptop.
  5. jeff652
    607
    623
    Idaho
    These tests show the benefits of performing preventative maintenance on your hybrid battery. You CAN extend the life of your hybrid battery by occasionally reconditioning and regularly charging/balancing it. We have our own graphs that show this on our website, and now there is independent Techstream results that support it as well.
    You can read more about battery reconditioning and how our patent pending Prolong battery sytems enable this enable this here:
    Prolong Battery Systems. Extending the life of your hybrid - Hybrid Automotive
  6. Iamjo20
    Iamjo20 Member
    259
    Thanks for responding!
    jeff652 likes this.
  7. S Keith
    799
    329
    AZ
    2003 Prius
    6 week test results added.
    Table updated.
    Conclusion added.
    Owner still very happy.
    Tester pleased with the results. :)
    Steve
    strawbrad likes this.
  8. Bobakanoosh
    Bobakanoosh Junior Member
    34
    Ogden, UT
    Jeff,
    Let's say I purchase the Prolonged Battery Reconditioning Pack. What do I need to "do" aside from pull everything apart? Do I need to do anything to the pack itself? Or is it more or less a plug and go? It looks pretty self explanatory, but I figured I would ask and see what all is necessary before purchasing the reconditioning pack?
    Jordan
    jeff652 likes this.
  9. jeff652
    607
    623
    Idaho
    Hi Jordan,
    There is the one time installation of the car harness. This take around 1.5-2 hours. After that the charger and discharger can be easily connected and disconnected in only a few seconds. Here is an overview of the battery reconditioning process that covers the process once the harness is installed:
    Battery Reconditioning - Hybrid Automotive
    And here is the installation instructions for the car harness itself:
    2004 - 2009 Toyota Prius Installation Instructions - Hybrid Automotive
    Jeff
    Bobakanoosh likes this.
  10. Bobakanoosh
    34
    Ogden, UT
    Jeff,
    I guess I'm still a little bit skeptical on how this system evenly balances each cell? From what I understand each cell could be charged to slightly different voltages, and if they aren't all balanced individually then it won't work properly? I'm smart enough to know that I am missing something, but not smart enough to figure out exactly what I'm missing haha
    Jordan
    jeff652 likes this.
  11. S Keith
    799
    329
    AZ
    2003 Prius
    Jordan,
    Your understanding is incomplete.
    The 24 hour grid charge passes the same current through all cells and drives them each to their respective 100% SoC. It overcharges the fullest cells at a safe level and allows the lagging cells to catch up. This is "top balancing."
    The subsequent pack discharge to lower voltage levels ensures full consumption of normal potential capacity as well as voltage depressed capacity. In one shot, this accomplishes what 5+ cycles with a hobby charger can do. This can be thought of as "bottom balancing".
    With this process, you have effectively expanded all CELLS (not just modules) to their maximum available capacity. A second 24 hr charge to 100% SoC ensures the pack is again top balanced, and this is the recommended state to resume operation.
    I'd like to think these results speak for themselves... an 8 year old battery went from barely functional to measuring over 2X previous capacity under a far more strenuous test. The car is now behaving "like new" according to the owner.
    100s of Honda IMA users have used the HA system to keep their packs operating for years AFTER an actual pack error has occurred.
    Steve
    Bobakanoosh and jeff652 like this.
  12. jeff652
    607
    623
    Idaho
    Yeah, what S Keith said. Not sure I could have said it better myself :)
  13. Bobakanoosh
    34
    Ogden, UT
    Jeff,
    I have been looking around to see what other pack chargers there are. I found the same one you sell on the website (at least it looks the same) on ebay. The kit on ebay is 369 plus shipping. On the website it is 399 plus shipping (for the 04' - 09' charger). What is the difference between the one on Ebay and the one on your website? From what I can tell, it looks like the Ebay charger doesn't come with the light bulb discharging unit while your website for sure does. Can you clarify? Because I would like the light bulb unit, but in case you have't noticed I'm kinda a penny pincher hehe.. So if the kit you are selling on ebay comes with that then I'll totally purchase it from there. What are the differences if any?
    Thanks!
    Jordan
    By the way I do plan on buying the HV pack. I'm just looking for the best price (I'm poor)
  14. jeff652
    607
    623
    Idaho
    Hi Jordan,
    The Prolong Standard Charger package is $369 on eBay and $339 on our website. eBay charges us 8% sellers fees which we don't have on our own website, so we pass the savings to you. The Prolong Discharge Ready Charger package is $349 on our website and not available on eBay. You need the Discharge Ready system to be compatible with our Simple Discharger, which is already included in the $399 Prolong Battery Reconditioning Package, also available only on our website.
    Standard Prolong Battery Charger systems are designed to be used as preventative maintenance for healthy hybrid batteries. The Standard system allows for charging and balancing of the hybrid battery, but does not support battery reconditioning (deep discharging of the battery). By using our Standard charger system as preventative maintenance, battery degradation can be significantly delayed and often eliminated for the service life of the vehicle.
    For batteries that are already showing signs of deterioration, the Discharge Ready version of our ProlongBattery Charger systems is recommended. The Discharge Ready versions are compatible with our ProlongBattery Dischargers. Many of our customers opt to perform in-car battery reconditioning, which requires both the Charger and Discharger. The Discharge Ready option by itself does not allow you to discharge the hybrid battery; a Prolong Hybrid Battery Discharger is required.
    Hope this helps,
    Jeff
  15. Bobakanoosh
    34
    Ogden, UT
    Jeff,
    That helps tremendously! Thank you! I will be purchasing the Prolong Battery Reconditioning Package tonight, and will hopefully be able to balance the battery this weekend or next!
    The only other question I think I have is would I be able to use another discharger to discharge? I like the idea of a regulated discharge that I can walk away from, but I don't think I can swing 700 dollars for that.
    Jordan
    #35 Bobakanoosh, Feb 18, 2016
    jeff652 likes this.
  16. jeff652
    607
    623
    Idaho
    The simple light bulb discharger is the most cost effective option. It does require manual monitoring, but since you are only doing this 1-2 times per year, for the cost savings the extra effort is worthwhile for most people. Of course we'd be happy to provide you with an Intelligent Discharger if you would prefer to go that route :)
  17. Bobakanoosh
    34
    Ogden, UT
    So I can not hook up like a B6 charger to the power supply you provide to discharge the pack? Like would that be safe?
  18. S Keith
    799
    329
    AZ
    2003 Prius
    A B6 can handle something like 12-15 cells in series. 168 of them would instantly pop the power MOSFET and likely many other components the second you complete the circuit. Even my beloved Reaktors will release the magic smoke at about 100V.
    Let's say it was even possible... the pathetic 5W power limitation would put the discharge current at 25mA nominal and would take 160 hours to drain 4000mAh to 1V/cell.
  19. Bobakanoosh
    34
    Ogden, UT
    Alright!
    So I received my HA Reconditioning Pack today and I'm super excited to get it going, I just had (hopefully) one last question! Do I NEED a mini VCI to do the reconditioning? I know it's nice to have one to read the codes, but I don't have a win 7,XP,Vista laptop and don't feel like dropping more money and time on finding and purchasing one at this point. If the balancing works, and the codes go away once I finish everything, then do I really NEED to read the codes? I feel like it would kinda be a waste of money if it's not essential.
    Any input would be appreciated!
    Thanks
    Jordan
    jeff652 likes this.
  20. S Keith
    799
    329
    AZ
    2003 Prius
    Not at all. The MiniVCI/Techstream was used for the before/after comparison.
    It is SO worth it... $30 well spent assuming you have a suitable laptop... like the $100 ones you can pickup on craigslist... :)
    jeff652 likes this.
