Quantitative Results of Grid Charge/Discharge
Discussion in 'Gen 2 Prius Technical Discussion' started by S Keith, Dec 6, 2015.
  1. HBS
    HBS Member
    74
    56
    MO
    Regarding the "switching of the bulbs" during discharge, I purchased the new HA discharger that automatically adjusts the discharge load and automatically stops at the desired voltage and I have good feedback for it. The service wasn't as good as when I originally purchased my first Prolong grid charger but nevertheless I recommend these over the light bulb discharging set up.
  2. tri4all
    tri4all Member
    99
    Pacific Northwest
    Hi keith and all. two questions after reading this thread:
    1. do you guys think that 250 W is too much for the first discharge? I have two 250W heat lamp bulbs from a bathroom fan. any thoughts?
    2. the prolong reconditioning procedure is basically a 3 charge and 3 discharge cycles one after the other. but what if we were to do a full charge and then a full discharge using the light bulb procedure, and we can still do this 3 times? wouldn't this accomplish the same? and it would significantly reduce the monitoring time between cycles?
    #162 tri4all, Nov 15, 2020
  3. tri4all
    tri4all Member
    99
    Pacific Northwest
    are these discharge voltage termination values outdated? I see on the prolong website that for the prius second or third generation the values are:
    first 134 V
    second 101 V
    third 84 V
  4. dolj
    dolj Senior Member
    8,446
    4,291
    Wellington, New Zealand
    Yes, HA has updated the termination voltages to what you saw on their website and quoted in your above post.
    jerrymildred likes this.
