Question-2025 Prius in EV Mode: Reply quickly!
Discussion in 'Gen 5 Prius Technical Discussion' started by iRun26.2, Jun 13, 2025.
Tags:
  1. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    That (4.4 mi/kWh) is actually dismal, let alone impressive.
    I routinely average around 6.5 mi/kWh in the city with my 2021 Prius Prime Limited. I can average 6.3 mi/kWh on the highway if I keep the speed at 55 mph or below. My record in the city was 8.1 mi/kWh (round trip, 25 mph).
  2. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    I have the most advanced models and it is rated as having less range than the cheaper models. Probably the more expensive models are both heavier and more wasteful of electricity because of the added functions.
    In any case, if I can get 4 miles / kWh , that still amounts to greater than 40 miles EV, correct? I find it confusing when the battery capacity is stated like 13.8 kW-hr yet the battery is claimed only used down to 25% (how many real kW-hr do we really get)?
    I am greatly looking forward to driving to work on Wednesday. This will give me a good idea of what time I can expect in the intended use for EV
  3. Gokhan
    6,715
    2,672
    Paramount CA
    The EPA formula is:
    Useable BEV battery capacity at the 240-V plug (kWh) = 33.705 kWh/ge × BEV range (mi) / mpge
    Useable BEV battery capacity at the battery output (kWh) = ~ (0.90 to 0.95) × 33.705 kWh/ge × BEV range (mi) / mpge
    0.90 to 0.95 in the second formula is the charger efficiency.
    The car displays the kWh at the battery output (not the 240-V plug).
    You can plug in the EPA numbers to the formula to get the mi/kWh on the car display. Basically it is mpge divided by 33.705 and then divided by (0.90 to 0.95).
    mi/kWh at the battery output = (mpge / 33.705 kWh/ge) / (0.90 to 0.95)
    Gen 4 PHEV is more fuel-efficient (higher mi/kWh) than the Gen 5 PHEV.
    The EPA rating for Gen 4 PHEV is 25 miles. I get around 38 miles in the city and 30–33 miles on the highway.
    iRun26.2 likes this.
  4. iRun26.2
    824
    169
    United States
    Why would they go backwards (Gen 4 PHEV > Gen 5 PHEV)? And by how much?
  5. iRun26.2
    824
    169
    United States
    One thing I don’t understand, and I’m certain you do, is the usable battery charge on the Gen 5 PHEV. If they cut off the EV at 25% (I’ve read this someplace) and only let it charge to 90% to 95% (read this somewhere too), was is the usable EV kWhr available for Gen 5 PHE?. I’d like to know, based on the miles/kWh I see how far I could expect my car to go on EV
  6. Gokhan
    6,715
    2,672
    Paramount CA
    You could look up the EPA mpge numbers. It's because Gen 5 is heavier and slightly less aerodynamic and has larger wheels with no wheel covers on higher trims, which makes it even less aerodynamic. 133 mpge vs. 114 mpge Gen 4 vs. Gen 5 higher trims, respectively. 127 mpge for Gen 5 SE.
    #46 Gokhan, Jun 17, 2025
  7. Gokhan
    6,715
    2,672
    Paramount CA
    About 1 kWh for HEV reserve and about 1 kWh each for upper and lower buffers. So, you have about 10.6 kWh remaining.
  8. iRun26.2
    824
    169
    United States
    Do you have any information on how the 2012 PHEV worked? Were there any buffers at all? I had one and repeatedly used every little bit of EV that was available to me. I now suspect that was not good for it.
  9. Gokhan
    6,715
    2,672
    Paramount CA
    I am not familiar with Gen 3, but its lithium-ion battery of half size as Gen 4's would have buffers as any lithium-ion battery, perhaps about 0.5 kWh each and a 1-kWh HEV reserve. That leaves about 2.4 kWh for BEV driving, which is consistent with the 11-mile range.
  10. Trollbait
    12,832
    Toyota prioritized looks and performance to help the declining sales. Seems to have worked with the numbers of new to Prius buyers.
  11. bisco
    52,888
    Looking at the gen 3 and 4 form factors, it’s hard to believe gen 4 was more aerodynamic
    daisy555 likes this.
  12. bisco
    52,888
    It was very similar with upper and lower buffers, and hev reserve.
    Over 11 years, I did a total of more than 60,000 miles pure ev, and about 25,000 of hev.
    Battery capacity was still 80-85%.
    Why do you think that is not good for it?
    Toyota designed these cars to run ev as much as you choose, with the caveat that we not let the gas go stale
  13. iRun26.2
    824
    169
    United States
    I never heard of any type of buffering way back in my 2012 version. I guess I was making the assumption too that Toyota may have done Honda did in letting the customer discharge the battery to a level that was unhealthy for the battery.
    Sadly, today, I gave the title to the junk yard. Now I’ll get my insurance payment of about $6600. My car was worth a lot more than that.
  14. iRun26.2
    824
    169
    United States
    At least I now have my new 2025 model. How I just look forward to driving it! :)
    Gokhan likes this.
  15. Gokhan
    6,715
    2,672
    Paramount CA
    Prius drag coefficient cd:
    • 1st Generation: 0.29
    • 2nd Generation: 0.26
    • 3rd Generation: 0.25
    • 4th Generation: 0.24
    • 4th Generation Prime PHEV: 0.25
    • 5th Generation LE/SE (17” wheels with aero covers): 0.27
    • 5th Generation with 19” wheels: 0.29
    iRun26.2 and bisco like this.
  16. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    We get 10.6 kWh for EV use. I can easily get over 50 miles of EV range but my car is an SE.
  17. iRun26.2
    824
    169
    United States
    What are your driving speeds and driving environment when you get 50 miles? That’s very impressive!
  18. iRun26.2
    824
    169
    United States
    It makes me wonder if I got the right car. I will wait and see what I get on my 22 mile commute to work tomorrow (65mph speeds but I may go slower). I wanted the fancy tech and thought the reduced efficiency wouldn’t be that noticeable.
    if I lose a lot of range I may need to charge most of the day at work and then the solar panel will go unused.
  19. iRun26.2
    824
    169
    United States
    And is yours a 2025?
  20. bisco
    52,888
    could you change to smaller wheels?
