Question-2025 Prius in EV Mode: Reply quickly!
Discussion in 'Gen 5 Prius Technical Discussion' started by iRun26.2, Jun 13, 2025.
Tags:
  1. iRun26.2
    iRun26.2 Active Member
    824
    169
    United States
    So, the power from the solar panel at that time is unused?
  2. Trollbait
    12,832
    Someone put the Toyota techinfo repair guide into a PDF here.
    Got evidence or just supposition? What prevents the car from combining and balancing the solar and DC-DC inputs?
  3. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    You made your first comment without any knowledge, and now, you are doubling down on it.
    It is simple EE. The main DC–DC converter runs at 14.1 V or higher when Gen 5 is plugged in. If the auxiliary DC–DC converter in the Gen 4 charger is an example, the solar charger auxiliary DC–DC converter only generates a float voltage around 13.0 V. Besides, they are not going to go through great lengths to design an “electronic power-split device” to splice them together. I have never seen two power supplies connected in parallel.
    iRun26.2 likes this.
  4. Tolarian Academy
    Tolarian Academy New Member
    Hillsdale, Michigan
    2024 Prius Prime
    XSE
    I'm a bit confused by your logic of not charging at work, I get that you like the idea of only having to charge once and using solar power to help make the round trip without having to plug in, but I would reverse how you are doing it and charge at work and try to make it home and back to work without having to charge at home, that way you are maximizing your post tax income and shifting the burden of the cost of charging to your work, giving you a slight added benefit to your work life.
    iRun26.2 and daisy555 like this.
  5. Gokhan
    6,715
    2,672
    Paramount CA
    Correct. The solar-charger computer likely turns off the solar charger entirely when the car is plugged in. As I replied to @Trollbait above, you simply don’t connect two power supplies in parallel, especially if they are running at different voltages, without going to great lengths to design complicated electronics. Last but not least, there is no need for solar power when the car is plugged in, as there is no vehicle-to-home (V2H) in Gen 5.
    However, this could likely change in Gen 6, as the car will feature vehicle-to-home (V2H) as the Gen 6 RAV4 PHEV does. In that case, you can use solar energy to help power your home.
    New (Gen 6) RAV4 makes world premiere in Japan | Toyota | Global newsroom | Toyota Motor Corporation official global website
  6. Trollbait
    12,832
    Then how does the gen4 solar roof help power the 12V circuit while the car is running?
  7. Gokhan
    6,715
    2,672
    Paramount CA
    In Gen 3, ity only powered the blower fan using a relay circuit. We need to find the drawings for Gen 4 and Gen 5. For Gen 5, they would be in the new-car features (NCF) manual on Toyota Tech Info, as the system is available in the US models.
    Solar Roof Schematic? | PriusChat
    #107 Gokhan, Jun 30, 2025
  8. Gokhan
    6,715
    2,672
    Paramount CA
    After reading Toyota’s comment that the solar charger “supplies the auxiliary battery system when driving,” it sounds like they may have included a 12-V power-switch device that switches between the solar charger and DC–DC converter while the car is being driven, with the switch being made according to the solar output, system load, and DC–DC converter voltage.
    When someone installs a 12-V-battery monitor in a solar Gen 5 Prius PHEV, we can get a better insight on this, as we will see how the voltage behaves in different scenarios.
  9. ChapmanF
    19,050
    I also don't know how they chose to do it, but if it were me I might just match the panel output to the 12-volt bus voltage with a buck/boost converter and let it contribute however many amps it's going to, and call it good.
  10. Gokhan
    6,715
    2,672
    Paramount CA
    Well, the main DC–DC converter voltage varies between 12.86–14.4 V according to the computer that controls it. I am guessing the solar-charger auxiliary DC–DC converter runs around 13.0 V to keep the 12-V battery at float.
    Again, a battery monitor would be most helpful to see how the system behaves under different solar-operation scenarios.
  11. ChapmanF
    19,050
    I'm just thinking about keeping component count and complexity down. In no other Prius is the 12-volt battery isolated from the rest of the 12-volt bus and treated somehow differently. There aren't relays clicking it in and out of the circuit. The voltage the DC/DC converter puts onto the 12-volt bus overall is chosen according to the ECU's idea of how much charging the battery needs.
    For that matter, a statement that the panel supplies the auxiliary battery system while driving could be true simply by dumping the power into the HV system ... which is already powering the DC/DC converter while driving, so the panel's contribution is included.
    What happens while the car is OFF may be where more cleverness lies.
    iRun26.2 and Gokhan like this.
  12. Gokhan
    6,715
    2,672
    Paramount CA
    I thought about, too. Perhaps there isn’t even a sub DC–DC converter and the solar charger only charges/powers the high-voltage battery and the main DC–DC converter turns on during solar charging (and driving) to power the 12-V system, with that way the solar charger indirectly contributing to the power. And when the car is plugged in, the solar charger turns off in order to prevent interference with the A/C charger. That could be the easiest way to implement it.
    Again, a 12-V battery monitor would give us concrete numbers during various solar operations.
  13. iRun26.2
    824
    169
    United States
    That is a very good point! I never looked at it from the financial standpoint of maximizing my charging at work to save my electrical bill.
    I just had a level-2 charger installed at my house yesterday. (That was expensive!) At work, I have to get out my 120V level-1 to charge from one of the available outlets outside our building. I like not having to drag my charging cable out of my car. I like just getting out of my car going to work and then I leave work without monkeying around with the charging cord. Now, at home, I simply plug in.
    Also, work is where I am using solar power to charge. My driveway at home is shaded. The car does nothing with solar power when it’s connected to a charger. And then there is the fact that I can’t get a full charge at work since it’s rare to work 11 hours for level-1 charging.
    I do like the idea of work paying for my car’s electrical fuel but it is not convenient and it makes the solar panel only useful while driving.
    Tolarian Academy likes this.
  14. iRun26.2
    824
    169
    United States
    Today was my record solar charge contribution. A while back, when I first started out, I was expecting to get around 4-mile days from a single days charge on most days. Today’s grand total was only 3.2 miles.
    I’ve been smiling the solar cells power contribution throughout the day and I’ve seen that it really doesn’t get above 50W contribution until 10AM here in Minnesota (and that’s with full sun). Then the two hours before noon and two hours after noon are in the upper range 145W to 175W. I have seen 185W but it is rare. The sun going under a cloud reduces output from 175W to 50W. Of course I don’t want to be checking too often as that costs some of the charge captured by the solar panel just operating the car to check the statistics. :)
    I have yet to see much more than a few hundreds of a percent gained during the day from the solar charge. I’m not sure where the 3.2 miles comes into play. The few percentages gained are easily dissipated. I’m not sure where my 3.2 miles comes to be real. I’m a little disappointed, maybe it goes into cooling the battery when it is in the hot sun???
    Now, with my level-2 charger, I can easily bring or retrieve my daughter from her friends house after a brief charge after coming home from work. Still no gas usage in the past two weeks. I love it! I think I’ve driven close to 500 miles in EV mode since I arrived home from Milwaukee (no gas usage yet).
    One thing is for sure, this newer Prius (2025) gets a lot hotter in the sun than my old 2012 version. I couldn’t even touch the door window controls today, they were so hot. They were simply too hot at first to touch!
    I do love my fast charger (level-2) at home! Hopefully there are some tax breaks available from my charger and installation payments.
    #114 iRun26.2, Jul 2, 2025
    Tolarian Academy and Gokhan like this.
  15. Gokhan
    6,715
    2,672
    Paramount CA
    What color are they (old and new)? It makes a big difference in heat absorption (summer) or loss (winter) whether it is a light or dark color. With a dark color, you will need a lot more cooling in the summer and a lot more heating in the winter over a light color.
  16. iRun26.2
    824
    169
    United States
    The old one was dark gray while the new one is black.
    I wish I could buy a cover that could protect my car from the solar heat. I wonder how much of my electric energy gained is necessary to cool down the traction battery.
    I bought a special cover for my new car that is supposed to protect I from hail damage but it covers up my solar panel. It is astounding how much money I have already spent on accessories/extras for my new car! The most expensive one (PPF and ceramic coating) comes next week. I am clearly obsessing over this new car!
    #116 iRun26.2, Jul 3, 2025
    Gokhan likes this.
  17. Gokhan
    6,715
    2,672
    Paramount CA
    Well, black will by far be the worst as far as heat/cold is concerned. They also claim that Gen 5’s large and horizontal windshield doesn’t help. I saw it, and it looks great though as long as you can keep it clean. It is certainly one of the best Gen 5 colors for aesthetics.
    Surprisingly, my Blue Magnetism Gen 4 PHEV hardly shows the dust at all. My Classic Silver Metallic one was worse at hiding dust. It is also a reasonably light color but not very light.
  18. iRun26.2
    824
    169
    United States
    Wouldn’t the black be beneficial in the winter for capturing heat from the sun to heat the car via the greenhouse effect?
  19. Gokhan
    6,715
    2,672
    Paramount CA
    Most of the heat during the winter will come from inside the car (how much sun is out there in the winter, either due to clouds or the low angle?). Black will lose more heat due to more thermal radiation; so, a black car will be colder in the winter. That is why insulating blankets are covered in aluminum foil to reduce thermal radiation. So, the more reflective (less absorptive) a surface is, there will be less radiative heat exchange with the outside, keeping the inside cool during summer and warm during the winter.
    The physical mechanism was described incorrectly at the seller site as the blanket reflecting body heat onto the man. In reality, it is because a reflective surface emits and absorbs less thermal radiation. The inside of the aluminum foil doesn’t need to be reflective for it to work. It is the same reason why heating and cooling ducts are covered in aluminum foil.
  20. Tolarian Academy
    Hillsdale, Michigan
    2024 Prius Prime
    XSE
    If you are getting close to running out of range on the way home since you are sometimes adding extra stops in, I would at least plug in at work on your lunch break or something so you can get most of your ev miles back, maybe try mixing in charging at home, then plugging in and topping off at work at lunch, then try plugging in at work the next day first thing and see how much charge you get. You could also look into adding some solar to your house if you are really digging the solar aspect and you have the extra funds. You will get a federal tax credit for any residential solar for installed in the next few years still I believe, you would have to check but I think it's something like 30% of the cost, and that would be one more thing that you could be tracking and nerding out over lol.
