Question about 2016 Toyota Prius Three Touring
Discussion in 'Gen 4 Prius Main Forum' started by SkyFlameMimi, Apr 16, 2019.
  1. SkyFlameMimi
    SkyFlameMimi New Member
    Sunnyvale, CA
    Three Touring
    I own a 2016 Toyota Prius Three Touring
    I want to know if my car will stop automatically before collision if I don't hit the break.
    Does anyone knows or tried please?
    Thank you.
  2. krmcg
    2,592
    2,393
    Whittier, CA
    Assume not...
    Elektroingenieur likes this.
  3. krmcg
    2,592
    2,393
    Whittier, CA
    What level of Safety Equipment is installed? Early 2016's did not come with all of the safety bells and whistles - they became "included" at a later date...
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Mine will hit the brakes - HARD. Not sure if it'll stop in time, because it's not come to that (usually a car crossing across in front, or a parked car on the bend of a road). But I think USA didn't have the full safety suite we got.
  5. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    Toyota does not guarantee the car will stop the car before a collision but it will attempt to slow the car to reduce the amount of damage or likelihood of injury.
    At slow speed in parking environments (or into the garage) mine applies the brakes when I'm within 1 foot of hitting something.
    kevin
    fuzzy1 likes this.
  6. Tideland Prius
    16,683
    It will only stop completely up to a certain speed (that's stated in the manual). Beyond that, it will only reduce the impact speed. Keep in mind that the value stated in the manual is not a hard and fast rule as there are many factors that dictate whether the car can stop completely (not an exhaustive list but it may include road surface type, debris on the road, tire type, tire grippiness, tire wear, weather conditions affect the road surface and so forth)
    fuzzy1 and alanclarkeau like this.
  7. alanclarkeau
    7,045
    7,593
    I don't thing the low speed parking version of AEB is on all cars - we don't get it here.
  8. Elektroingenieur
    2,515
    3,288
    Three Touring
    According to the 2016 Prius sales brochure (PDF), Toyota Safety Sense-P with Pre-Collision System (PCS) was standard equipment on the Three Touring, so it’s likely that your car has this feature.
    As footnote 28 in that brochure states, however: “The Pre-Collision System is designed to help reduce the crash speed and damage in certain frontal collisions only. It is not a collision-avoidance system and is not a substitute for safe and attentive driving. System effectiveness depends on many factors, such as speed, driver input and road conditions. See your Owner’s Manual for further information.”
    I encourage you to review the information about PCS in the Owner’s Manual (PDF), on pages 275–288. As @krmcg kindly pointed out, it’s unwise to assume that the system will work under any particular conditions, nor to try to test it.
  9. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I've had the PCS warning pop up a couple times on my '16 three touring when approaching a car turning out of my lane. My judgement says I will clear the car based on him continuing to turn at the normal speed, but the car thinks otherwise and beeps and flashes a red BRAKE warning on the screen. Does not apply brakes, though.
