Question about a Gen II brace....
Discussion in 'Newbie Forum' started by AJP, Dec 12, 2012.
  1. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In theory, if the Pounds per Square Inch is the same in both tires, and the car weighs the same, the foot print of a wider tire will be shorter front to back and have the same area as the narrower tire.
    In practice the tire has inherent rigidity and is not 'perfect', but the shape is somewhat shorter.
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    ive ran the bt plate for 6 years and it works great, very easy install and rock solid.
    I have no way of knowing if other plates work better since I'm not taking this one off to try.
    The Prius is shaped like a bullet built to withstand wins head on and cut through head on, but stinks with sideways gusts.
    Alan...
    Sent with Tapatalk 2
  3. richard schumacher
    7,682
    1,062
    United States
    My experience was, after about six weeks I got used to the twitchy, wandering feeling and it became completely normal. So you might just hold off a bit before spending any money on it.
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Part of the learning curve for me was getting used to the steering. There's very little feel, and no 'dead spot' in the middle. When I unlearned old habits, I was happier with the Prius. The handling still needed fixing, but the steering problem was solved.
    richard schumacher likes this.
