Question about Battery Bar on Prius 2018
Discussion in 'Gen 4 Prius Main Forum' started by Kenashi, Apr 3, 2026.
  1. Kenashi
    Kenashi New Member
    2018 Prius
    Hello everyone. I bought a 2018 Prius with 75k. The Prius drive fines and no issues so far. However, I see that the battery bar stays at 2 and sometimes goes up to 4-5 bars. This is normal? I need to be worried about the Hybrid battery? Is my first Hybrid car I want to make sure that everything is working as expected.
    52,826
    yes, completely normal. check the o/m to see if there's any mention of it. the bar will be anywhere and everywhere at different times and situations.
    uphill, downhill, cruising, stop and go, idling, hvac use, city vs highway and etc.
    you only need to start worrying when it quickly bounces back and forth from full to empty to full, etc.
    that means you have diminished capacity, which shouldn't happen for a long, lone time.
  3. BiomedO1
    BiomedO1 Senior Member
    4,576
    2,404
    Left Coast
    Follow the link to your answers.
    Toyota Manuals and Warranties | Toyota Owners
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    In earlier Prius generations the hybrid battery SOC (State of Charge) display was a range of 40 to 80%. Beats me if the Gen 4 gauge is the same. Time for me to go looking down the rabbit hole of my Owners Manual.
    EDIT: Doesn't mention it in the OM. The Google AI says the Gen 4 display is 40 to 80% (AI can make mistakes, so double-check responses).
    #4 AzWxGuy, Apr 4, 2026
  5. BiomedO1
    4,576
    2,404
    Left Coast
    As I recall, there are several battery vs engine usages screens to choose from. You can toggle through them to see which display you like better.
  6. Kenashi
    Kenashi New Member
    2018 Prius
    Thanks everyone for your responses Im still learning about the car and sadly I got a problem with ten ac system. I will open a new thread to verify how to solve it.
  7. Charlie M
    Charlie M Junior Member
    Georgia
    I have a 2016 with 63000 miles, my bar goes from one bar to all bars. I get the all bars when driving mostly down hill. I get one bar leaving my house with just a few bars to start and drive slowly (uphill) until the engine cuts in).
  8. bisco
    52,826
    sounds right
