Question about carbon clogging in egr system
Discussion in 'Gen 3 Prius Main Forum' started by Jim Caldwell, Jan 28, 2022.
  1. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    I have a 2014 Prius at 165k miles. The gas mileage is not what it should be. I got the car at 140k from a dealer, so probably the egr system has never been cleaned. I hear it will set a code P0401 ( I think) when its clogged up. I have techstream, and it hasnt set this code. Will i get a chk engine light for this dtc also?
    I am 70 yrs old. I did recently replace spark plugs and coil paks. Seems like my mpg even decreased a bit after this instead of helping. But cleaning the egr system, i think its just too big a job to try to do this myself. I think it needs to be done at toyota dealership. How much should a mechanic shop cost to clean the egr and intake? ( or the number of hours it should take so I can do the calculation myself) Problem is--- besides expense--- is that I dont trust either of my two dealerships. I have really no confidence that they would actually clean it out. Theres no way to tell if they really did.
  2. Tombukt2
    Tombukt2 Senior Member
    13,860
    2,519
    Durham NC
    It's about an 8 bolt job or so all up on top of engine I believe 1/4 drive ratchet a few wrenches on a 75 degree day no issues I'm you're age too . On tech stream you can read the flow of egr in HG numbers I cannot rem how lowis getting bad 14 comes to mind Chapman I think recently posted the numbers good luck buddy .this exact problem blew my 2013 engine crack in no 2 piston crown . Now new engine
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    They won't clean it, they replace the parts. And it will be expensive.
    If you can change the spark plugs, you are about half way there.
    It's not really hard, just takes time. If you take your time and take one part at a time,
    you can do it.
    Use a pressure washer and oven cleaner on the egr cooler. And "Gunk" on the intake manifold
    and other plastic parts. Don't use the oven cleaner on the egr valve though.
    Maybe someone is near you from Prius Chat that would be willing to help you.
    mikey_t and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    If we only knew where or which Mathis :whistle:.
  5. Tombukt2
    13,860
    2,519
    Durham NC
    How bad is the gas mileage??? I was still in hi 40's at no 2 cyl fail . Like 46 47 similar to my gen2 .then no 2 code I knew what that stumble was is..
  6. Mendel Leisk
    42,345
    If you can get to the plugs you're halway there. See first link in my signature.
    70's not that old, is it...?
    Montgomery likes this.
  7. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Not really ...until you look into the mirror!
    Montgomery and Mendel Leisk like this.
  8. ChapmanF
    19,020
    It's kind of a grueling job in a Gen 3 liftback. In a Prius c, the stuff is more exposed on the top of the engine, but in the liftback it's kind of buried off the inboard end of the engine and under the cowl.
    The thread about monitoring the flow test results is this one. You can watch trends over time in the flow results and see what is happening way earlier than the point where a P0401 would be logged. That's very easy and comfortable to do, nothing but plugging in to the diagnostic port in the cabin.
    The flow test results don't really cover the four individual passages in the intake manifold itself. Those are better just directly inspected now and then. But that job is easy.
    mikey_t likes this.
  9. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    "Mathis is a city in San Patricio County, Texas, United States. The population was 4,942 at the 2010 census."
  10. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
  11. ChapmanF
    19,020
    "Mathis is an unincorporated community in Dallas County, in the U.S. state of Missouri."
  12. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    Another question: when the egr system is getting clogged up, what are the symptoms?
  13. ChapmanF
    19,020
    From uniform clogging (the kind the self-test can detect), not much in the way of symptoms. The ECM has the flow test results and it controls how far the valve opens, so there might be nothing obvious, until one day it decides the clogging is too much and sets a P0401 code.
    From nonuniform clogging among the four small intake manifold passages, you can get an engine that runs smoothly at low throttle and at full throttle, but gets a bit rough at mid loads where EGR is used. The EGR valve opens at those mid loads and then you have some cylinders getting too much EGR and some too little, resulting in roughness.
  14. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    Okay.....so loss of mpg isnt a symptom of clogged egr passages?
  15. rjparker
    rjparker Tu Humilde Sirviente
    11,101
    6,966
    Texas Hill Country
    $800-$1000 at a dealer who will install a new egr cooler and valve. You will get no improvement in mpg unless it was totally clogged and giving you the code. An independent mechanic "might" do it for a couple hundred less if he has experience doing it on a Prius of this generation.
    In most cases, reduced mpg is caused by an old high voltage battery. Or short drives of a few miles or less. Or high speed driving of 70 or higher.
    If we knew where you lived you might get mechanic recommendations. If you still have start up rattles and brake booster codes I would not spend much time or money on the egr system. Repairs to the engine could include a refreshed egr if you shopped carefully.
    #15 rjparker, Jan 30, 2022
  16. Mendel Leisk
    42,345
    165k is a symptom of clogging.
    Someone reported blown head gasket symptoms with a v, today, with around 120k:
    Violent shake and Misfire | PriusChat
    m.wynn likes this.
  17. ChapmanF
    19,020
    Who knew?! Keep the EGR unclogged and the car never gets old!
  18. rjparker
    11,101
    6,966
    Texas Hill Country
    Mendel has disclosed a previously secret rollback option for used cars. "Entrepreneurs" no longer have to pull instrument panels and send them to one of our helpful Priuschat members. No more unnecessary shipping delays. Now they clean the egr with oxiclean and a carwash and the miles dissolve away.
    Since we have guys from Monterey:
  19. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    Ok. I think i will do the egr & intake myself, buying a used but cleaned cooler, and a new egr valve. There are quite a few new egr valves up for sale in 175.00 price range on eBay. These parts are p/n 04004-58137 and the vendors say they are for years 2010 thru 2012. Really? Will they perhaps fit in any gen3 car (mine is a 2014 prius) to yr 2015? Or was there a different valve used in first 2 yrs of gen 3 production?
    PriusGuy32 likes this.
  20. Mendel Leisk
    42,345
    Finding a fully cleaned cooler for a reasonable price might be a tall order. And cleaning the valve is quite easy. That's a lot of $'s to save a few hours labour. With your miles I'd just clean what you have, and would likely be best to replace the pliant gaskets on the intake manifold. That entails the interfaces with throttle body, cylinder head and egr pipe.
    FWIW when I did ours around 70K kms, I replaced nothing.
