Question about coming to a stop and the brakes
Discussion in 'Gen 2 Prius Main Forum' started by yarzy, Sep 29, 2006.
  1. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    To avoid the suspension-relaxation lurch, pop into neutral just
    as you get to your stop. No more creep, until you want it. Make
    sure the engine's off first, though.
    _H*
  2. AAWADKE
    AAWADKE New Member
    71
    <div class='quotetop'>QUOTE(hobbit @ Nov 28 2006, 01:17 AM) [snapback]354723[/snapback]</div>
    I am not sure if Driving a HYBRID should be like driving an Airplane. Its like making sure you have your flaps down ....landing gear deployed....etc etc..??
  3. vince31
    vince31 New Member
    25
    on the oil change thing, the UK dealer told me that there was no intermediate or initial oil change/service required and the service interval was 10K miles. Car is 1 month old with 1200 miles on the clockso far.
  4. sumi&#39;s_man
    sumi&#39;s_man New Member
    <div class='quotetop'>QUOTE(hobbit @ Nov 28 2006, 02:17 AM) [snapback]354723[/snapback]</div>
    Hobbit, the neutral-brake, rust-scrubbing trick worked like a charm. A few stops from 35 mph down to zero, and now the last few feet of my stops are smooth again, no matter how lightly I feather the pedal. Why do you say to "make sure the enine's off" before shifting into neutral? Also, would fairly frequent shifting into neutral to make stops cause premature wear in any way?
  5. ctmurray
    ctmurray Member
    121
    <div class='quotetop'>QUOTE(yarzy @ Sep 29 2006, 12:24 PM) [snapback]325662[/snapback]</div>
    I also noticed this effect as well. I did not know why, thanks for asking and the good explanation by others.
  6. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    I don't think it can be made to "go away" forever. I notice it worse both when it is very damp/rainy, or if the car has been sitting a few days. I think it is a function of the brakes not staying clean all the time. I notice the "grabbiness" goes away after a few good brake applications....until the next time.
  7. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    When I replaced my 2005 with a 2007 I noticed that the brakes on the new car were a bit grabby when rolling to a stop. As far as I can tell it is getting better, (I have about 1200 miles on it now). I seem to have read that Toyota is using a coating on the rotors during shipping to keep them from rusting, and I suspect (although I have no proof) that at least some of this grabbiness is caused by this coating. It's either that or just the brakes not being bedded in yet. Either way it should improve over time. Remember that the friction brakes only get used under hard braking or under 8 MPH, so it takes quite a bit longer to bed in the brakes or wear off the coating.
  8. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(daniel @ Sep 30 2006, 06:20 AM) [snapback]325999[/snapback]</div>
    I don't follow it. Mostly because I sometimes need to carry bicycles on my car. But I'm a wild man. I changed to Mobil1 at 1k miles.
  9. sub3marathonman
    sub3marathonman Active Member
    557
    75
    <div class='quotetop'>QUOTE(darelldd @ Dec 1 2006, 03:34 AM) [snapback]356113[/snapback]</div>
    Woo Hoo!!! I guess I must be pretty wild too. :D I changed to Mobil1 at 980 miles.
    But before everybody gets upset at such low milage for the oil change, the recommended time period of six months to change the oil was up. Also, I got the oil analyzed at Blacksonte Laboratories in Indiana.
    They found high levels of Copper (34 when it should have been 1) and Silicon (104 when it should have been 14). The report said "High wear and silicon are both common finds in new engines. The wear is high due to break-in of new parts, while silicon is from sealers and sand-casted parts. ... The TBN was still strong at 6.1, so the oil has plenty of active additive left. 1.0 is a low reading. Look for better wear and silicon next time."
  10. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    <div class='quotetop'>QUOTE(hobbit @ Oct 1 2006, 06:22 PM) [snapback]326683[/snapback]</div>
    I've been shifting into N just before stopping for a smoother stop. (I also was unnerved by the abrupt braking in the Prius). But don't shift into N too soon, since it disables regenerative braking and you lose more energy to the friction brakes.
  11. lowspeed
    lowspeed Member
    267
  12. PriVusLY
    PriVusLY Junior Member
    30
    Appleton, WI
    <div class='quotetop'>QUOTE(efusco @ Sep 29 2006, 12:29 PM) [snapback]325667[/snapback]</div>
    I plainly disagree.
    What varzy described is not the transition from regen to friction braking. That happens near 7 or 8 mph. He stated that it happens below 5mph. This is also not the engine shutdown shudder, which can occur after completely stopped.
    This brake sticking is not "normal". If it was normal it would have been reported numerous times since Prius birth. It is "new" behavior that seems to have arisen with the 06's. Those of you who do not own 06's are being rather dismissive of something that you do not have experience with. Drive an 06 for a period of weeks, and then report back.
    It is not something varzy (or anybody else) should "get used to". I encourage those of you who are experiencing a brake sticking/grabbing problem during the last few feet of a stop, to plainly report the problem to a dealer every chance you get. Until enough dealers report the problem up the chain, there will be no action.
  13. PriVusLY
    30
    Appleton, WI
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 29 2006, 02:29 PM) [snapback]325734[/snapback]</div>
    varzy is describing behavior "just" before the stop, not the regen to friction transition. This brake sticking is not normal and is a problem. At times, when it occurs, it can be very noticeable and visibly shake and/or rock the vehicle during the last few feet of a stop.
  14. PriVusLY
    30
    Appleton, WI
    <div class='quotetop'>QUOTE(sumi's_man @ Sep 30 2006, 09:04 AM) [snapback]326012[/snapback]</div>
    Very good description of the driver/car interaction, and your intentions. From other reports on PriusChat, others have the very same intentions and also find it very difficult to produce a smooth stop. But this is something that doesn't seem to be the case prior to the 06 models. This is not normal behaviour. I encourage you to bring it up to the dealer, and don't let the dealer brush it off as "normal".
  15. PriVusLY
    30
    Appleton, WI
    <div class='quotetop'>QUOTE(hobbit @ Oct 1 2006, 08:22 PM) [snapback]326683[/snapback]</div>
    If you are suggesting this should go in the FAQ's, as a way of deflecting queries about something that is supposedly part of the "normal" operation of the Prius, I disagree.
    I have tried the bandaid you suggest. The results are very short lived. The brake sticking behavior re-appears, sometimes within minutes, on the dryest of days. Rust formation? That quick?
    This is a problem, and should be exposed as such. Drive an 06 for a few weeks and report back.
    <div class='quotetop'>QUOTE(beethoven @ Nov 27 2006, 04:01 PM) [snapback]354571[/snapback]</div>
    22K and still rocking?? Wish it weren't so.
    This is a definite problem. From reports, the brakes do not work that way prior to 06. Please report it to your dealer. It is the only way we all will get something done about it.
  16. McShemp
    McShemp New Member
    371
    SA, TX
    You should demand a TSB immediately! Don't let Toyota brush you off either.
