Question about Daytime Running Lights on Prius V
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alexfair, May 3, 2010.
  1. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    I was told by my insurance company that I could only get the DRL discount (about $32.00/year) if the DRLs were "factory installed", and not an add on system. I have a V and just leave the lights on all the time for safety. It's is a bit of a pain, because the panel lights have to be adjust to full bright during the day, and turned to the night time setting at night. This affects not only the panel light brightness, but the GPS screen as well.
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
  3. dejongj
    dejongj Member
    171
    Whipsnade, UK
    You would like the uk version then. I have the led pack which comes with auto headlights. However the side affect I noticed is that the satnav and HUD etc seem to operate automatically independently from the headlights. Which is rather good.
  4. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    But isn't your display dim all the time now?
  5. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    You can adjust the brightness to daylight mode even when the headlights are on. Turn the brightness wheel all the way up, then there's a detent, then it clicks into daylight mode.
  6. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    I am glad my Prius doens't have forced DRL's, if I want DRL's I will turn on the head lights. when I pull out of the garage in the mornings I don't like having the headlights blinding me by reflection off the wall.
  7. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    You, along with everyone else in this group are unbelievable! I just clicked the wheel into full bright mode. Now, I'll just leave the headlights on all the time. I didn't force the wheel because that's when I break things :p
  8. macman408
    1,179
    367
    I'm apparently on a roll with my last post, so I'll try my luck again here.
    Paint the wall black? ;)
    chrisj428 likes this.
  9. pat767
    pat767 Junior Member
    63
    Which size of tube did you use? Which color? Can we see a pic?
