Question about error message,"Check Hybrid System"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sylvio Briffa, May 6, 2017.
  1. Sylvio Briffa
    Sylvio Briffa Junior Member
    Oakland,CA
    Working on the shocks yesterday, I had to disassemble all the trim panels to access the shock absorbers. I disconnected the negative cable to my 12 volt battery for safety. Having heard on the chat that I should clean the battery cooling blower fan, I decided to remove the high voltage safety plug. I removed the blower and cleaned it out and reinstalled it and left all the trim panels off. I reinstalled the high voltage plug and 12 volt battery. When I turned the car on, it would not engage in drive or reverse. It would go to neutral. On the dash board the message said, "Check Hybrid System." Any ideas out there what can be going on? Signed disparate owner.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    reset by turning on and off your car 3x
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Are you sure you seated the orange safety plug and locked it? That's a typical issue upon reinstall.
  4. Patrick Wong
    18,210
    6,517
    Most likely the high voltage interlock was not correctly installed. On G2 for example, after the lever is pivoted 90 degrees it must be slid to be locked in place.
    Mendel Leisk and Raytheeagle like this.
  5. Mendel Leisk
    42,293
    Just to pile on: it's probably that orange plug on the hybrid battery.
    I disconnect nothing before cleaning that fan, no problems.
    Disconnecting the 12 volt in particular is a bit of a pain, if not warranted: you lose radio presets, trip meters, and maybe the window auto-up function needs re-learning.
    Also, in my experience at least: a 12 volt disconnection causes the car to act a bit strange for the next drive or two, doing odd revving-up, as if it's recalibrating.
    Sometimes you absolutely should disconnect 12 volt, but I don't think this is one of those cases.
    #5 Mendel Leisk, May 6, 2017
  6. Sylvio Briffa
    Oakland,CA
    Could a dead or discharged 12V battery cause it not to start?
  7. Sylvio Briffa
    Oakland,CA
    I installed it properly
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Does the "ready" message display? How old is the 12v? Has it ever been discharged (light left on, door not closed, etc)?
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Even though missing the last of three steps when replacing the orange plug is very common.
    We will have to defer to your assessment that you, indeed did all three steps:
    Step 1) Insert plug
    Step 2) Swing handle upwards
    Step 3) (often missed) SLIDE THE HANDLE VERTICALLY DOWNWARDS UNTIL YOU HERE IT CLICK.
    Here is Carolyn's video showing the 3 step process.
    Other things to check
    Did you plug both of the fan harnesses back together?
    1) Smaller Plug on the back of the fan itself.
    2) Wider white plug to the upper right of the fan.
    As a prank I've unplugged those before.
    It disables the car. :) Heh.
    Otherwise take a moment to scan the vehicle to obtain the error code.
    It will tell you what is wrong... such as P0A0D - High Voltage System Interlock Circuit High.
    (o.k., o.k. I won't mention that again)
    Raytheeagle and Robert Holt like this.
  10. bisco
    52,803
    yes, a bad 12v will prevent starting.
