Question about GFI / GFCI outlet for PiP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Vulcanman, Jul 21, 2013.
  1. Vulcanman
    Vulcanman Junior Member
    68
    Since this will be dedicated outlet (single 20A 120V outlet) ... I am told that I will remain in compliance with codes. I plan on not making it a GFCI due to the tripping issue. I will not be using it for any other purpose.
  2. Dan Cathy
    Dan Cathy Junior Member
    126
    The only time my GFI tripped was during a thunder storm.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    FTM
    Power sources
    Connect to an AC 120 V outlet (NEMA 5-15R) with a Ground-
    Fault Circuit-Interrupter (GFCI) and a circuit breaker. Use of a
    15A individual circuit is strongly recommended to ensure
    charging cable will operate properly.
    When charging outdoors, make sure to connect to a weatherproof
    outlet that is certified for outdoor use.
    Checking Ground-Fault Circuit-Interrupter (GFCI) operation
    before its use is recommended.
    Just to make you feel better. I have had my plug-in for 16 months and have never had a tripping issue, ever!!!!
    I followed the above to the T ! I did use 12 gauge wire,
    If you plan on 220v charging in the future 12 gauge can work, but you might consider running 10 gauge wire to help future proof. :)
    So if you have a 20A GFCI I am sure you will have no problem at all!
    Enjoy your Plug-in ! :D
  4. Vulcanman
    68
    Thanks for the info. So did you use GFCI breaker or a GFCI outlet. Those GFCI breakers are more expensive than GFCI outlets.
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    Just the 15A breaker in the house, 12 gauge wire to garage and GFCI outlet in garage.
  6. hill
    9,026
    If you're absolutely positively certain that PiP's (or other plug-in you may own some day) will never charge any faster on 240v than the current on board charger charges at ... you'll do just fine with only a 20 amp circuit. If subsequent Rev's (that you may own) charge faster though, you'll be hosed ... as the wire gauge (and length of run) that you use NOW, determines how much you can upgrade to a heavier breaker in the future. It's not that much more to go heavier. We put in a 40 amp breaker and matching gauged wire, so that we can charge at 7.5kW's. Our forward thinking paid off just a few days ago, as a plug-in stopped by - that utilized the faster / higher power current:
    Guess the Plug-In | PriusChat
    In one hour, they got enough juice from us to travel almost 30 miles. Can't do that on a 20amp circuit. Mind you, it'll only matter if you get a quicker charging plug-in some time down the road. Personally I like to be over prepared for tomorrow ... but maybe that's just me.
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    Just wondering what size wire 10 or 8 ? Thanks.
  8. Vulcanman
    68
    NEC recommends 8 ga for 40A.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    (y) Thanks!
