Question about key
Discussion in 'Gen 3 Prius Technical Discussion' started by vday, Feb 11, 2014.
  1. vday
    vday Member
    312
    Israel
    I tried using my second set of keys this morning and it appears that the battery is dead or nearly dead.
    I was able to open the door with the key, but when the car asked me to place the key on the power button it didn't work. Any ideas?
    BTW - I wasn't stuck as I was home and able to take the other key.
    Also when I took the FOB case with me the car did go into ready mode so it appears that the battery is not completely dead.
    Shouldn't the car operate with only the (metal) key?
    Thank You
  2. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    The fob has to be placed on the start button, not the key.
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    It sounds like you held the metal key up to the power button the first time. The RFID chip is in the fob case, so it is the fob that should be held next to the power button.
    That's why it worked later when you had the fob with you.
    vday likes this.
  4. vday
    vday Member
    312
    Israel
    Thanks
    Yes that is exactly what I did
    It said key so I thought it meant the metal one
    My mistake
