Question about LCD screen
Discussion in 'Gen 2 Prius Audio and Electronics' started by Sandro Gonzalez, Oct 28, 2018.
Tags:
  1. Sandro Gonzalez
    Sandro Gonzalez Junior Member
    Miami, Florida
    My 2004 prius have the screen faded and I found at the junk yard a monitor from a 2007, but this one have navigation on it. I swapped but it doesn't work at all. It is because my screen doesn't have navigation or because the one I bought is broken.
  2. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
    The donor MFD (MultiFunction Display) could be broken. BUT, it is more likely b/c your 2004 came with the low-Res MFD and you are trying to upgrade to a Hi-Res MFD.
    It might be possible to "upgrade" the MFD with some manipulation of the pins (wire harness or MFD).
    Best bet is to find a donor MFD from a car that does not have back-up camera. IIRC (If I Recall Correctly), all Prius with a back-up camera come w/ a Hi-Res MFD.
    Try contacting Steve at Autobeyours. He has parts and does repairs too.
    Prius MFD Touchscreen Repair
    #2 exstudent, Nov 4, 2018
  3. Sandro Gonzalez
    Miami, Florida
    Thanks so much for the recall, I guess I'm gonna return the part.
