Question about Multimedia and headlighting dimmer
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Argyros, Feb 20, 2024.
  1. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    Hey all,
    I've been searching out a way to not have the Multimedia dim when turning on the headlights. Problem is, if it's not pitch black out, then it's almost impossible to read the multimedia on the 'dark' setting when lights are on. It's ok at night, but during the day, I have to turn of and on lights when I need to read my map or radio information, because it's too dark to see.
    Any thoughts? I don't want to turn it back to light/white settings, only to brighten the screen on Multimedia when the lights are fully on.
  2. ChapmanF
    18,976
    On my (much older) gen 3, there is a "display" screen and button, with a "day mode" setting.
  3. Argyros
    275
    142
    2023 Prius
    I checked the display in the manual, and there should be a way to keep the display at 'Day' settings. I'll check it out this weekend.
    Thanks, ChapmanF!
  4. Edward Morgan
    Edward Morgan Junior Member
    30
    23
    Kentucky
    2023 Prius
    I have been having the same issue. I have checked everywhere for the answer including my dealer during the 5000 mile service and have not found an answer yet. I believe this is a LE only problem.
  5. Argyros
    275
    142
    2023 Prius
    Well, changing the Brightness and Contrast on the Media Display screen worked wonders! I still can't see it when I wear my sunglasses, but can pretty easily see the Multimedia screens (even the Android Auto) even though I normally wear reading glasses. Thanks again for the tip!
  6. artieb
    artieb Junior Member
    75
    22
    medford ma.
    2024 Prius
    Limited AWD-e
    Leave the headlights on Auto position and you still have DRLs
    I leave screens on dark position
  7. Argyros
    275
    142
    2023 Prius
    The LE doesn't have the Auto option on the headlight stalk.
