Question about new hybrid battery
Discussion in 'Gen 3 Prius Main Forum' started by Gerald10, Jun 14, 2026.
  1. Gerald10
    Gerald10 Junior Member
    38
    I will ask them the following - feedback? whats the expectation for the voltage difference?
    Hi xxx,
    Just to summarize what we discussed over the phone yesterday:
    • I submitted a screenshot from Dr. Prius showing the Internal Resistance warning and the permanent P0A80 code.
    • There are currently no other active trouble codes visible besides the permanent P0A80 code. Also, there is no master warning light (red or yellow triangle) illuminated at the moment.
    • I attached another screenshot showing the internal resistance of each battery module. The internal resistance of battery module #3 is 36 milliohms, and the battery cooling fan runs almost continuously, which was not the case with my previous battery.
      • For reference: A good, new NiMH battery should typically have an internal resistance in the low 20 milliohm range. A 10+ year-old or degraded NiMH battery is usually around 30 milliohms. New sodium-ion batteries are typically around 15 milliohms.
    Can you please confirm that the installation of the replacement battery will be provided at no charge and that I will not be charged any fees?
    Also, if the replacement battery does not show an improvement in quality or performance (not in the range for 20 milliohms), I will request a refund and reinstall my original Toyota battery that I provided to you.
    Thanks,
    Gerald
    Brian1954 likes this.
  2. JC91006
    16,936
    8,647
    This is all unnecessary. You paid for a new battery, you should get a new battery. Why does it need to test a certain level? Open the case before they install it. Take a few pictures for your evidence of what is inside. Make sure it looks new and have them install it.
    You can post the pictures here later and we can tell you what type of battery you got. For you to go through all these steps in buying a BRAND NEW battery shows you don't even trust this company yourself. Why are you going through with this transaction?
  3. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    You should have purchase the Sodium Ion Pack from Jack.
    They you would KNOW it is brand new. No "remanufactured"(used), or "rebuilt"(used).
  4. Brian1954
    Brian1954 Senior Member
    2,669
    1,068
    South Central PA, USA
    The Dr Prius app does not tell you if the P0A80 code is current or a permanent code. Are you using a different scanner to read the codes and it says the P0A80 is permanent code?
  5. Gerald10
    38
    i have a Autel MaxiAP AP200 OBD2 Scanner Bluetooth Wireless OBDII Auto Diagnostic Tool - will that tell me more about the P0A80 error?
  6. Brian1954
    2,669
    1,068
    Yes, it will tell you if the code is active or a permanent code.
    Open the first link I provided in post #19 for a description on how to set up everything.
    #26 Brian1954, Jun 17, 2026
  7. Brian1954
    2,669
    1,068
  8. FrankNPrius10
    FrankNPrius10 New Member
    Colorado
    Sorry to hear batt pack replacement issues. I chose reconditioning vs replacement.
    Two 2010's: 160K and 210K. As mpg fell to high 30's/low 40's, I started investigating, concluded if pack reconditioning/balancing was a reasonable DIY, then why not. Added extra work elements that were batt related.
    1. Pulled pack atop plywood in cargo area.
    2. Pulled, cleaned cooling fan, all ductwork, including adding stiffeners to keep plastic open.
    3. Added snap-in fine air intake grille over existing.
    4. Removed pack tin shroud; straightened same.
    5. Removed wiring, then buss bars.
    6. Recording carefully, used CQ3 devices to recondition each cell following Gregg Fesco's YT vid.
    7. Balanced cells in situ via snaking bare copper; 24 hours.
    8. Installed new nickle plated buss bars.
    9. Reassembly is the reverse.
    Takes 5 to seven days, less if one uses two CQ3's (~$400).
    Results:
    210K = 50.1 mpg; 160K = 52.3 mpg.
    Pack Reconditioning shall happen at 100K intervals.
    Good luck.
    F
  9. FrankNPrius10
    Colorado
    Update on the 210K mileage 2010 Prius: at last gas fill-up, mpg calc'ed as 55.4.
    I'll be doing a "5K Miles Service" today. A large part of which is reducing known movement resistance conditions:
    1. Maintain tire pressure as Driver's Door + 5psi.
    2. Rotate tires fore and aft.
    3. Wheels off, check, replace pads, rotors if needed.
    4. Remove caliper assemblies; thoroughly clean guide pins and pin recesses; lube; reassemble. Sticking pads against rotors creates heat and reduces mpg.
    5. Usual other actions:
    + Change engine oil, filter
    + Check all fluids, including 12V battery.
    + Spare psi.
    + Torque four window wiper assembly nuts to 20 ft-lbs.
    + Blow out engine air filter
    + Vacuum hybrid battery cooling system intake grille.
    + Check Oil Catch Can system; remove residue, if any.
  10. Hybrid Battery Exchange
    Gresham, OR
    You don't need to open the cover to see whats inside, you can get peek by removing the upper plastic vent, the opening should be large enough to take a picture of the battery inside. The likely installed the Ennocar cylindrical modules.
    It's normal for the P0A80 permanent code to remain after battery replacement, it will self clear after a few drive cycles. If the scan tool is showing current P0A80, look at the freeze frame battery block voltages for the smoking gun.
