Question about Pandora on Entune
Discussion in 'Prime Audio, Electronics, and Infotainment' started by jburke313, Mar 31, 2017.
  1. jburke313
    jburke313 Member
    48
    North Shore, Massachusetts
    Should the stations from my existing Pandora account show up on the Entune app? Or do I have to create new stations in the car, spate from my linked Pandora account?
  2. CharlesH
    2,798
    1,166
    Roseville, CA
    My experience has been that it picks up your the favorites from your existing account.
    HPrimeAdvanced likes this.
  3. jburke313
    jburke313 Member
    48
    OK, thanks. Maybe I just need to give it time to grab the data. I will let all know if I continue to have trouble.
  4. jburke313
    jburke313 Member
    48
    Ok so the stations finally synced up.
    But now I notice when streaming Pandora through entune the volume is much lower than fm/xm, etc. didn't see anything in manual yet but not halfway through it yet
  5. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    I have same problem, but haven't dealt with it yet since I usually listen to NPR, or talk radio. I just cranked up the volume when I did listen to Pandora, but that's not a real solution. Let me know what you find out if you get an answer.
  6. ttait
    ttait Active Member
    273
    163
    Southern California
    The actual audio comes from your phone, so make sure your phone bluetooth volume is set high as well. This can be demonstrated by changing phone volume (on the phone) while you are listening to Pandora.
  7. jburke313
    jburke313 Member
    48
    I did that, ttait. Still very low. Thanks though!
