Question about PCB behind the 11.6 screen
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Kragzakh, Sep 8, 2023.
  1. Kragzakh
    Kragzakh Junior Member
    Boston, MA
    Long story short, I'm curious if anyone happens to know if the PCB that is directly behind to screen is the same for all versions of the 11.6" unit?
    I'm hoping I can use the PCB (and possibly the entire screen assembly) from a 2017's E5702 to repair a damaged E5708 from a 2020.
    (Pictures are screenshots from a youtube video demonstrating disassembly to repair a screen.)
    Thanks.
  2. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    When I had to replace my MFD with a used one, the exact same serial number unit needed to be purchased. You can see the serial number in the bottom right front of the screen, I believe.
    If they match, you should have no issues. Since they don't, I am uncertain what portions of the MFD differ from other units. Usually they are sold and replaced as a single unit (display, circuit board and computer "box") that is attached with what looks like 2 screws only.
    Toyota charges $9k for a brand new screen. Got mine used for $1200.
  3. Mendel Leisk
    42,205
    It may just be me, but just in case:
    PCB = Printed Circuit Board
    I think.
  4. Kragzakh
    Boston, MA
    Yes, sorry, the printed circuit board.
  5. Mendel Leisk
    42,205
    I probably say EGR about a dozen times a day. :unsure:
    Danno5060 likes this.
  6. Igor331
    Igor331 Junior Member
    Kazakhstan
    2018 Prius Prime
