Question about range indicator
Discussion in 'Prime Main Forum (2017-2022)' started by edgar.edgar72, Dec 14, 2017.
  1. edgar.edgar72
    edgar.edgar72 New Member
    US
    I bought my prime in March and I love it. I charge overnight, and until recently my range indicator would read 31.9. in the last few weeks that number is going down. Now it's at 25.2. Anyone know why my starting range is decreasing?
    Nexus 6P ?
  2. xray22
    xray22 Junior Member
    31
    Vanouver, WA
    Probably because it's getting colder. Is happening to me too.
  3. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    If you're driving the same way, over the same roads, the very cold weather will reduce your EV range. Are you using the heater? That will impact mileage. I'm in Southern California, so our boring-hot weather lets us get continual good EV range, as long as we're able to navigate the High Speed Animals on the road!!
    stevepea and priuscatprimeguy like this.
  4. Mendel Leisk
    40,582
    Where in the US are you? Big factor.
    HPrimeAdvanced likes this.
  5. ForestBeekeeper
    ForestBeekeeper Active Member
    766
    302
    Maine
    My mileage drops when the temps drop.
  6. edgar.edgar72
    US
    Nashville
    Nexus 6P ?
  7. Trollbait
    12,351
    It's getting colder.
    Check your tire pressure, that will also drop with the cold.
  8. bisco
    51,154
    the range indicator is based on a formula of past usage and the state of battery charge. it is not a guarantee of how far the car will go in ev, but usually a pretty good estimate unless other factors change such as; hills, speed, weather, acceleration, hvac usage, tires pressure and etc.
    if nothing has changed, see your dealer before the warranty runs out.
  9. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    Most everyone knows “winter blend gasoline” reduces your MPG. I wonder what effect Winter electricity blend has on economy? :)
  10. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    doesn't "blend" very well:cry:
    HPrimeAdvanced and benagi like this.
  11. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Heck, I just use my Mix Master mixer and have no problems; just set it on High!! Har, har!
    priuscatprimeguy likes this.
