Question about replacing front plate bracket
Discussion in 'Gen 3 Prius Main Forum' started by popvldc, Feb 19, 2016.
  1. popvldc
    popvldc New Member
    Mid Atlantic
    How easy is it to replace the front license plate bracket? I'm assuming you just unscrew the screws from the old one and screw the new one back in but since it's just screwed directly into the bumper holes, will the new installation require different size (larger diameter) screws?
  2. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    Same screws should be fine, just try and find the old threads when you screw them in (turn them backwards slowly until you feel them slip into the old threading).
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Yes, be careful, they are just screwed into the plastic bumper-cover. And there are only two. Not very strong.
