Question about rims
Discussion in 'Prime Main Forum (2017-2022)' started by greenquark, May 16, 2021.
  1. greenquark
    greenquark Junior Member
    montreal
    2020 Prius Prime
    Hello there,
    I am noobie so sorry if this question has already been asked. My Prius came with 195/65R/15 and the rims are 15 X 6 1/2 J ET 40 5 x100 bolt pattern. I have another set of tires for winter same size (195/65R/15 ). I am looking for another set of rims for the winter.
    Are rims 15 X 6 J ok ? If so what would be the correct ET value for 15x 6J ?
    Thanks in advance
  2. jteran5
    jteran5 Active Member
    410
    202
    2019 Prius
    XLE AWD-e
    If you want it to "stick out" just as much as the OEM wheel, you would need a +35 offset. But those are not that common in a 15x6.0. The most comment offset is a +45 which are the stock OEM size of the gen2 prius wheels.
  3. Dilpills
    Dilpills New Member
    OC
    2021 Prius
    Hey man, what size rims are you running?
  4. greenquark
    montreal
    2020 Prius Prime
    So are the 15x6 +45 ok for the prime? Will they fit? What would the cons?
    Can the gen2 Prius rims fit the prime?
    thank you in advance
  5. jteran5
    410
    202
    2019 Prius
    XLE AWD-e
    They will fit 100000% with even more room to spare as the wheel is narrower and more into wheel well. I had the gen2 wheels installed about 4 days after getting my brand new gen4 because of the weight savings and I loved the look.
    Even with 20mm spacers, there are still no issues in clearance. Last pic is with the 20mm spacers 20200118_145132.jpeg 20191219_140113.jpeg 20200726_123951.jpeg
  6. greenquark
    montreal
    2020 Prius Prime
    Hummm nice but I am referring to fitting the gen 2 rims to a Prius primeā€¦ not Prius gen4. I want to be 100 % sure. Sorry for asking again :
    Can 15 x 6 1/2x ET 35 rims be replaced by 15 x 6 ET 45 rims?
  7. jteran5
    410
    202
    2019 Prius
    XLE AWD-e
    The prime and gen4 have the same wheels..... So yes. The gen2 wheels will also fit.
  8. jteran5
    410
    202
    2019 Prius
    XLE AWD-e
