Question about the Prius transmission
Discussion in 'Gen 2 Prius Main Forum' started by PaulHS, Nov 17, 2008.
  1. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    I guess it really comes down to how you define a Prius. What components, features, and attributes are necessary to call it a Prius?
  2. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    I think a manual HSD transmission might be doable. Here is how:
    1) Lever with haptic (force feedback when one pushes so that MG1 does not go overspeed) and variable range limits (hard limit to avoid MG1 going overspeed) - controls engine to wheels rotational ratio. Full forward is max ratio, full back is min ratio.
    2) Left Foot Pedal push pull - controls electric power on push, and electric regeneration on pull. Neutral position - no electric input or output, unless battery needs charging/depleting. Dash panel light to indicate when pedal is partially over-ridden. Pushing on center (brake) pedal locks left pedal at neutral position.
    3) MG1 is controlled based on computer programing during Left Pedal push.
    4) Brake pedal can be switchable to be as is now, or only friction brakes.
    5) Taking foot off right pedal (accellerator pedal now) results in engine stoping, unless speed exceeds 40 mph. Otherwise the left pedal is a direct match to engine RPM.
    So, lets do some accelleration/decelleration thought-experiments, to see if its practical.
    1) Accelleration - Both left and right pedals pushed, and one lifts off right pedal as one gets to speed. Lever is initially full forward (at stop) and pulled back to match engine Revs to wheel revs - engine revs set by right pedal. Car recharges battery as one cruises along.
    1a) Transition from accelleration to cruise - left pedal is lifted, and lever pulled even further back until haptic force is felt. Based on degree of force, driver pushes pedal to keep engine RPM's practical. Car cruises along at min RPM, max ratio.
    2) Braking - Left pedal is lifted, until 7 mph, then center pedal is pushed. Will probably need some kinda beeper that goes to a solid tone at 7 mph to do this right. Lifting foot off right pedal to go to brake, turns off engine. As car slows - haptic forces lever forward, or driver can preceed the hard limit moving the lever by moving it. If driver wants engine to cut, and the car is below 40 mph, pulling against the haptic force tells the car to go into a glide.
    3) EV maneuver - one uses left pedal as go/slow pedal. No application of right pedal at all - engine off.
    This is getting pretty complicated - not quite helicopter level , but close.
  3. grand total
    grand total Member
    154
    ON, Canada
    I didn't really mean to start a fight or anything, I just hate the use of the word "impossible" when it's not. FWIW when I originally posted what I envisaged was some sort of (2-speed) transmission following the PSD in the powertrain. As we know the Prius is not able to exert it's maximum power until it reaches 45 MPH or so (I can't remember the exact number) and a higher numerically final drive ratio might be welcome at low speeds and in hilly areas in reverse.
  4. richard schumacher
    7,682
    1,063
    United States
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Wow, the old discussion of HSD vs. IMA topic. HSD superiority became more clear to a lot of people after four years. It was not clear back then....
    You can also read Wayne Geredes' (xcel) negative view of Prius on page 13 and on...
    John1701a joined in the discussion on page 15. This discussion did not get ugly like the 'Are hybrids up to the chore?' thread which got removed.
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Lexus LS600h has dual stage HSD that you just described.
  7. patsparks
    10,664
    569
    Adelaide South Australia
    When will Prius come in a 2 range all wheel drive configuration? Just move half of MG2 to the back axle.
  8. Patrick Wong
    18,210
    6,515
    :confused:
    The 4WD-i version of Highlander Hybrid has an MGR which powers the rear axle. The Highlander model is named Kluger outside North America - have you noticed this sold in Australia?
  9. patsparks
    10,664
    569
    We have Kluger here but not in the hybrid form. I know of the highlander butI was thinking an AWD Prius for stability and safety.
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I didn't say much on that particular thread 4.5 years ago. But what was posted certainly was profound: Prius will become the icon for change... the one that inspired this new age in automotive history.
    Sweet!
  11. grand total
    grand total Member
    154
    ON, Canada
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Having SRU does not mean it will have dual stage. SRU adds a second planetary gear-set and Dual Stage (with SRU) adds a third planetary gear-set.
    Below is the RX 400h Transaxle:
  13. richard schumacher
    7,682
    1,063
    United States
    What are those chassis connections: clutches? If so, eww!
  14. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Richard,
    In the GS/LS schematic those are clutches.
    In the RX transmission the chasis connections are just fixed locatings. No Clutches. Just locating the bearings and motor stators, and keeping the planet carrier from turning.
  15. richard schumacher
    7,682
    1,063
    United States
    So, to be clear: there are no clutches in the 2010 Prius?
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I don't think so. Dual stage HSD is only for muscle hybrids. I don't think 2010 Prius will have it.
  17. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Rich and USB,
    The dual stage HSD is to give a cruising speed up around 100 mph, and a max speed somewhat north of 125 mh.
    SO, no, there probably wont be clutches in the 2010 Prius.
    In the HSD's with clutches, is the clutch engaged for slow speed operation? If not, then a failed clutch transmission would still work just fine up to about 80 mph.
    I think there are two reasons Toyota is doing this. With $50 in gears, they can get rid of the $75 chain and cogs, and reduce motor cost to about 2/3's of what it was. Those prices are guestimate volume vendor price to Toyota. To buy replacements from Toyota through a dealer would probably be 3 times the cost. This also allows the transmission casing to be smaller, which saves aluminum and aluminum refining energy.
    The disadvantage is high rotational speed of MG2, which means one really really wants to keep that AT fluid changed on schedule, if not earlier.
