Question for the group - transmission oil change at 159k miles?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by amahastpl, Dec 21, 2022.
  1. amahastpl
    amahastpl Junior Member
    New Jersey
    Question for the group.
    Should I change my transmission oil at 158k miles?
    2013 Prius C. Nothing wrong with the car. I followed the maintenance schedule to the letter, but somehow never thought about the 'good for the lifetime' transmission fluid.
    I know it's a Prius. I know it has a CVT. I know I should have done it at 30k. I know fluids degrade over time...
    Anybody had a 'late' transmission oil change? Any problems? Any recommendations?
    Many thanks,
    Mike
    49,490
    if you're keeping it, absolutely. no problems reported here, many have done late changes
  3. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    It's no big deal either way. Toyota never specified a replacement interval for the ATF. They don't think it will ever need to be changed.
    Some members have changed theirs and noticed... nothing other than a lighter color in the new fluid.
    It should be understood that the Prius CVT is unlike all the others on the market: there are no friction parts bathed by this oil. No clutches, no drum and band assemblies, no chain and sheave stuff, none of that. Also there is no torque converter. No friction means no particles shed and suspended in the oil. Far less heat is generated by pumping action. There is some heat from the motor-generators and this will cause the ATF to darken over time, but you'll never feel any of it from the driver's seat.
    The upshot from all of that is that a Prius is far more gentle to its ATF than just about anything else on the road. Change the fluid if you feel like it- the car won't mind. But don't feel like you need to- this isn't a Subaru/Nissan/Honda CVT.
    Sonic_TH likes this.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    964
    631
    Monument, Colorado USA
    Yep, should be fine. I took a risk and did one on my daughter's used 2012 Sienna and, after a year, haven't had any issues. (A very neglected van...I've changed out all the fluid and suspect they were all originals except engine oil...yikes.)
    Make sure you only refill with Toyota World Standard tranny oil and have a breaker bar...those drain/fill bolts won't give up easy!!
    valuequest likes this.
  5. PriusII&C
    PriusII&C Active Member
    370
    129
    San Jose, California
    I changed one Prius at 60k miles and another Prius at 100k miles. No difference in cars' performance.
    However, I changed my Camry's ATF at 210k miles. The difference was obvious.
    ColoradoBoo likes this.
  6. amahastpl
    New Jersey
    Thank you all,
    This is what a 9 year old, 159k miles Prius C transmission oil looks like.
    Slightly brownish instead of reddish. No burnt smell. No suspended particles.
    Damn, an amazing car...
  7. Sonic_TH
    Sonic_TH Active Member
    545
    88
    Puerto Rico
    Looks very good for being years old and having 159,000 miles.
