Question from a Gen3 Prius owner
Discussion in 'Gen 4 Prius Main Forum' started by iskoos, Nov 17, 2018.
Tags:
  1. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Hey Guys,
    I am a proud owner of 2010 Prius III. I talked about this car so much that my roommate ended up getting a 2016 Prius two Eco.
    He showed me his car. Very nice!..
    I powered it on(after an overnight cold) and immediately realized that the engine didn't start after about 12-15 seconds which would always be the case for Gen3 Prius. And I absolutely hate that.
    I liked this a lot and talked about it over at the Gen3 forum but some members questioned this claiming that this wasn't reported before.
    So I wanted to ask the real Gen4 owners here.
    Do your Gen4 start the engine within about 15 seconds when powered on (with foot on brake)?
    All this when you do not drive the vehicle. You are just sitting in it and waiting.
    Also consider your HV battery is sufficiently charged.
    Thanks
    krmcg, bisco and Mendel Leisk like this.
  2. krmcg
    2,592
    2,393
    Whittier, CA
    That is correct. No startup penalty on the Gen 4 Prius. If the battery has sufficient charge and your climate control is set for a friendly number, the gasoline engine will not automatically start...
    bisco, Tande and Mendel Leisk like this.
  3. CIDPUSA
    CIDPUSA New Member
    Diamond bar
    Four Touring
    It only does that on cold days to heat up the engine
  4. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    Also the engine temperature has to be above 20°C (68°F) or it will revert to Gen3 behavior.
    So for your first turn-on on of the day it will probably start immediately (like gen 3) but will not when you use it again later in the day as the engine will still be warm.
    kevin
    Mendel Leisk, krmcg and bisco like this.
  5. bisco
    52,854
    okay, that just negates post #2, and answers o/ps question in the negative.(n)
  6. bisco
    52,854
    also, what good is just sitting in the vehicle, and not moving it?
    Starship16 likes this.
  7. kevinwhite
    333
    200
    Los Gatos Ca
    Sorry for the confusion - I didn't read the OP's question enough to notice that he said a cold engine. Maybe I'm wrong - I thought that was the behavior and seemed consistent with mine but I cannot find documentation to support that.
    I just tested it on mine and it started but it only has 4 bars on the hybrid battery.
    I'll have to check over the next couple of days now the weather is cold enough - much of the time in California it doesn't get below the 68° limit to show this behavior up.
    kevin
  8. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    To prepare yourself for the rush of exhilaration when you step on the accelerator.
  9. iskoos
    415
    254
    Orlando, FL
    This will hardly be a problem in the sunshine state. We were in 90s till a few days ago:eek:
    When I tried it on my roommate's Gen4 the other day, the engine had been sitting overnight.
  10. iskoos
    415
    254
    Orlando, FL
    You sometimes may change your mind, or you may just want to move your car in and out of your garage with the battery power only.
    Having the ICE automatically come on has no valid point to me. This should have been left to the driver.
    krmcg likes this.
  11. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    As others have said... If there's no need to start the combustion engine then it won't start it because there's no need, and this is often the case in warmer weather or when the engine is still warm. It often does start after around the time you mentioned though, even just sitting there.
    You can also often prevent it starting for longer by pressing the EV Mode button. This will attempt to use electric only power for as long as possible.
    In both cases though, harder acceleration, low HV power, high electrical drain, the cabin temperature being significantly different from the climate control temperature, hard braking, high speed, and so on, will coerce the combustion engine to start up.
    I don't quite understand why you hate the combustion engine not starting immediately, especially when the whole point of a hybrid vehicle is to reduce the use of the combustion engine to a minimum, but if you really want it to start, just press the accelerator while still in P and it'll fire up. If you want it on all the time while driving then drive in B mode.
    One of the beauties of the Prius is you can sneak out of your property in "stealth mode" (electric).
    So why do you hate the combustion engine not starting up immediately? I much prefer the opposite.
    Anyway, EV Mode to (maybe) prevent ICE starting, P + Accelerator and B mode to prevent it stopping.
    Robert Holt and krmcg like this.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    My experience with the Gen 4 is, if the ambient air temperature is 14 deg C or above, the HV battery has 3 or more bars, the climate control is switched off and I last used the car less than a day ago then the engine doesn't come on until needed.
    krmcg and Mendel Leisk like this.
  13. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    It's been in the low 50's every morning in my area of LA County, California.
    Anything below 60 degrees, and the engine usually comes on almost immediately after pushing the start button.
    What's the big deal?
    I prefer it that way.
    I want the oil to be flowing, and everything getting warmed up before I'm cleared for takeoff... :LOL:
    #13 Starship16, Nov 18, 2018
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Oil will always be flowing before the ICE starts up, the electric motor spins the ICE up to 1000 rpm before throwing fuel and spark at it.
    jerrymildred likes this.
  15. Starship16
    1,348
    1,455
    Beach Christmas
    Thanks, that's interesting. My engine comes on immediately.... within 1or 2 seconds after pushing the Start button. That happens after the car has been sitting all night.
  16. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The key is to ensure Climate Control is OFF - I go from the POWER button to Climate Control OFF buttons as a natural action when starting - then to EV button. And it's as long as the Hybrid Battery has at least 3 or 4 bars (it's sometimes fired it up with 3 saying "low battery".
    BUT - it will make insignificant difference to your l/100km, unless you're just moving the car a short distance - like outside to wash it. It has to warm the ICE up sometime.
    But I like to creep out of my street silently as a protest against the Harley, the Ducatti and 3 neighbour's cars which have minimalistic exhausts.
  17. Starship16
    1,348
    1,455
    Beach Christmas
    Thanks Alan. I usually turn off all HVAC before I get home, and park for the evening. (Old habit.)
    So nothing in "on" the next morning, when I power up the Starship.
    If it's cooler, the ICE kicks in. Doesn't bother me. It's quiet. I leave right away.
    I just drive it. Like any other car. :) Try not to even think about the ICE, EV, MPG, etc. I'd go NUTS if I had to "analyze" this car every time I drove it! :LOL:
    #17 Starship16, Nov 18, 2018
    alanclarkeau likes this.
  18. bisco
    52,854
    this all sounds exactly like gen 3 to me
  19. bisco
    52,854
    there's the rub. if you can move the car in and out of the garage, in and weather, with any battery level, without the engine coming on, that would be a programming change from the gen 3.
    as it is, you can find threads here where people move there gen 3 out of the garage without the engine coming on, but getting it back in is the challenge, unless it is warm out, the battery has more than 3 bars and the engine is not stone cold from disuse.
  20. iskoos
    415
    254
    Orlando, FL
    Wow you got me completely wrong there. What I hate (or lets say very much dislike) is when the ICE automatically come on when I do not want it.
    I went and reread my original post and it could be taken the wrong way I understand.
    When I was saying "I hate that" I was referring to the automatic start up feature of Gen3 within the 12-15 seconds window.
    Thanks your input anyways...
