Question from a Gen3 Prius owner
Discussion in 'Gen 4 Prius Main Forum' started by iskoos, Nov 17, 2018.
Tags:
  1. dbf
    dbf Member
    78
    86
    NE Ohio
    If the engine is warm, then I can get away with using only ev power for a few minutes as long as the power requirement is low and the environmental control temp setting (HVAC) is set such that I don't need engine heat. But the engine needs to be warm. If the engine is cold, then it will start regardless!
    52,849
