question on 12volt
Discussion in 'Gen 2 Prius Technical Discussion' started by fortheanimals, Jan 13, 2007.
  1. fortheanimals
    fortheanimals Junior Member
    87
    portland, or
    hi all,
    i keep my prius in portland, where i go to school. two or three times a year, i leave my car in a lot while i fly home. usually, the car is unused for about a month. i do not disconnect the 12 volt before leaving the car.
    wondering how much of a discharge the 12volt goes through in a month. the first time i drive the car again, i try to take it out on the freeways (to keep the ice going) for a consistent half hour, at least.
    is this a necessary thing to do any recharging?
    should i take my car into a shop and test battery level?
    would more and more month-long abandonments have some detrimental affect on 12volt?
    unrelated q:
    is there a reason for the snowflake icon to begin at 37F? seems an arbitrary temp.
    thanks.
  2. kDB
    kDB New Member
    241
    Fenton, MO
    <div class='quotetop'>QUOTE(fortheanimals @ Jan 13 2007, 08:50 AM) [snapback]375122[/snapback]</div>
    As long as your not draing the battery to near dead, it is not going to make a very noticable difference on the life. You also don't have to run the ICE to charge the 12 volt, it will charge from the hybrid batteries.
    For a month of storage, as long as you turn off the SKS system (button under the steering wheel) if you have it, there should be no problem.
    Basically it's warning you when the temperature is getting close to freezing. A lot of weather stations use the same temperature. 37°F is 3°C. After taking out 1°C for error, that's only a 2-4°C warning.
  3. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    I got at auction for about $30 each the older generation battery minders from VDC
    http://www.vdcelectronics.com/batteryminder_12117.htm
    I sure wouldn't pay $70 for one though.
    I was having problems with my 12 vdc battery so got into the habit of plugging in the battery minder every night. Works fine now, but I also have secure underground parking to keep the car in too.
    If you will be parking in a garage or other secure environment, then some sort of battery tender will help you feel better and not worry about a flat battery. A solar charger may also work, though keep in mind the cigarette lighter plugs are *not* live when the car is powered down. You would have to hook directly to the 12 v battery in the hatch.
  4. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    You can increase battery life during your absence by disabling the smart key system. There's a button under the steering column on the dash.
    If you don't have smart key, then that's one less thing to think about.
