question on codes.
Discussion in 'Prius v Technical Discussion' started by C acampora, Jul 30, 2020.
  1. C acampora
    C acampora New Member
    massachusetts
    Hi all. My question is, will the codes tell if the hybrid system stalled and shut down? Yesterday my 2012 Prius V wagon had the check engine light come on, then the hybrid system light then a bunch of others come on and it shut down. I had 3/4 tank of gas in it and battery indicator dropped to 1 bar. When I run the codes it reads system too lean bank, Evaporative Emission System incorrect purge flow, P0455
    Then Manufacturer control p3190. When I checked the 12v battery (thanks to a post from one of you!) it read 12.2. I turned the car on and it dropped to 11 but back up to 12.0. The car will light up etfc but engine won't run. Do you think this could be related to the recall from 2018? I checked my VIN and apparently I didnt get that fixed. Thanks for any input
    52,402
    welcome!
    the codes (as read by tech stream) and the service manual, will lead you in the right direction.
    why don't you get the recall done first?
    your 12v is a little low.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,545
    6,620
    Texas Hill Country
  4. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    You need the inverter update. That won't fix it but comes in handy when the inverter blows....
    There are actually 2 firmware updates..... but still expect it to go out.
