Question on EV/EV Auto buttons
Discussion in 'Prime Main Forum (2017-2022)' started by kevin54, Dec 22, 2016.
  1. kevin54
    kevin54 Member
    57
    65
    New Hope, PA
    Hello,
    Just got my Prius Prime Premium this week and love it so far. My third Prius. I've been charging it once a day in my garage - when I take it out after being fully charged, it automatically runs in EV mode. I believe my sales lady said I would need to push the EV button and then once it ran out it would then go into HV mode.
    So I guess it seems everything happens automatically? I've read a few confusing (for me) threads about others who are selecting these buttons to maximize mileage in EV mode - is this true? I also didn't think the car would run in HV mode if the battery was fully charged - is this so?
    What really are these buttons for, and you do any of you use them? It seems confusing to me. I'm guessing that if you are in HV mode with a depleted battery and then go down an enormous hill and the battery is sufficiently charged, you can then select the EV button to run it in EV only mode?
    Thanks,
    Kevin
  2. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Congrats, Kevin. Others here can answer your questions. Enjoy the ride.
  3. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    Congrats.
    The EV button has a few settings and yes you can run in HV mode with the battery fully charged, although you will lose a little EV range due to the HV mode using the EV battery when doing its thing. There is really just one battery pool, and it just goes down from the top (at least my understanding). There are essentially three modes I am aware of EV, EV Auto and HV mode. There is technically a 4th mode that most people will tell you not to use which is Charge Mode which will charge up the EV battery while driving. There are times this may be appropriate in certain conditions but in general probably isn't.
    If you push the EV button you will see it cycle through modes on the display. You can also push the HV/EV button to flip between HV and EV mode. There is a functional guide that covers what the buttons will do in the manual. Depending on current mode the button has different results.
    In EV Auto mode the car tries to make intelligent decisions on when to run in EV and when to flip over to HV mode. In EV mode you are instructing the car you want to run in EV mode even if the car would otherwise pick HV. In HV mode you are saying run the gas when I am driving above a fairly low speed. This is like operating a normal Prius, although it may not try as hard.
    The two buttons are a little different. The HV/EV button can not activate EV Auto.
  4. kevin54
    kevin54 Member
    57
    65
    New Hope, PA
    Thanks for the response Captmiddy! I know my sales woman also said that when in EV/Auto mode, the car would only run in EV mode up to 21 MPH (not sure if this is true). Yes, I did see the chart in the manual and it still seems confusing to me. I've seen references to Charging mode here also but not sure how that's accomplished.
    BTW, when you refer to the EV button, do you mean the Drive Mode button (to cycle between ECO Mode and PWR mode?). I don't have an EV button, just an HV/EV button and an EV/Auto button, as well as the Drive Mode button.
    Thanks,
    Kevin
  5. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    Hi Kevin,
    Yes, the HV/EV Button will switch between EV only mode or Hybrid. The car turns on EV mode by default when starting up. You can manually switch to EV Auto, I think Gas Engine kicks in around 84MPH on the freeway or something under EV Auto. In EV mode, the Gas engine kicks in faster and earlier than EV Auto.
    If you hold the HV/EV button, it will switch to the Charge mode. Press and hold again to exit that Charge Mode.
    Drive Mode is completely different from EV/HV/Auto. It has to do with how much power you want while driving. I noticed the ECO mode really slows down the car, in terms of acceleration.
  6. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    We have played with modes a little. I am not certain why we need so many modes.
    It seems to us that in EV when outside temps are -F it takes a really long time for the cabin to warm up and for the defrost to begin clearing the windshield. So we have been running the ICE to help generate warmth.
    We have also played with the CHG mode, it does bring up the battery charge fairly quickly.
  7. kevin54
    kevin54 Member
    57
    65
    New Hope, PA
    Thank you! That makes sense that the default mode is EV upon start-up. Yes, the ECO mode does make the car feel more sluggish, at least on my Gen3 it did. But I think for now I'll leave things be and not fiddle with the buttons. I'll drive it in EV until it depletes and then drive in mixed EV/HV. BTW, yesterday on my return trip I had depleted EV already and went in HV the entire way (it was only 30 miles or so) but my mpg for that leg was 68 mpg! I couldn't be happier!
    Regards,
    Kevin
  8. kevin54
    kevin54 Member
    57
    65
    New Hope, PA
    Thanks ForestBeekeeper! That makes sense on a real cold day. So far I've garaged mine but that won't always be the case,
    Regards,
    Kevin
  9. PriusPrimeOwner
    PriusPrimeOwner New Member
    29
    US
  10. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Eco mode setting is kind of worthless because there is a separate eco button for the a/c system, so all it does is remap the throttle. Never used power mode on my liftback either.
  11. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    It's still very handy for those of us in the north who will be using the engine for heat at times.
    The ability for ECO to lower the coolant threshold reduces gas consumption.
  12. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    What does that mean, and how is it different than air conditioning eco mode?
  13. bisco
    52,773
    a separate eco button for a/c, or hvac?
  14. Lee Jay
    5,850
    4,036
    Owners manual Page 490.
    Air conditioning eco mode
    The air conditioning system is controlled with low fuel consumption prioritized such as reducing fan speed, etc.
    Press [Eco Heat/Cool]
    The air conditioning eco mode switches between on and off each time is pressed.
    “ECO” is displayed on the air conditioning screen when the air conditioning eco mode is on.
    Toyota calls the entire HVAC system the, "Automatic air conditioning system".
  15. bisco
    52,773
    exactly.
  16. john1701a
    12,840
    5,312
    58
    With gen-3 came ECO mode, which would lower the "engine on" threshold from 145°F to 114°F for the coolant temperature. That enabled the heater to run longer when the engine was off, since that trigger could be adjusted by the driver. It resulted in less gas being consumed.
    With PHV came a tiered approach, dropping thresholds even lower depending on heater settings and battery-pack temperature. (I've seen it down to 82°F). That resulted in an even greater return from ECO mode.
    You need an aftermarket gauge to see the sophistication of the system. Toyota does not provide that level of detail in the owner's manual.
    #16 john1701a, Dec 23, 2016
  17. bisco
    52,773
    you're saying eco mode will still do this, even though there is now a separate hvac eco button?
  18. john1701a
    12,840
    5,312
    58
    I would suspect we get 2 settings because there are now 2 heaters (gas & electric). Having control over both would be nice.
  19. bisco
    52,773
    good point. maybe the new eco button suppresses the heat pump and the old button the engine temp threshold.
  20. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    In EV Auto mode, under what circumstances do you see it switching over to HV operation? I'm hoping that it's something along the lines of EV mode except when:
    • Out of battery,
    • >55MPH,
    • Very-high acceleration, or maybe
    • Climbing reeeally steep hills.
    Is it roughly along those lines?
