Question on the Prius Prime 2020 battery
Discussion in 'Prime Fuel Economy & EV Range' started by Justabrake, Sep 19, 2019.
  1. Justabrake
    Justabrake Junior Member
    Prius Prime 2020 battery question
    Does the battery stay for days or even weeks without losing strength if the car is parked and not used
  2. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    To preserve the lifespan of the battery, it's best not to keep it fully charged for an extended period of time.
  3. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    There is no discernible difference. BUT it is bad for the battery to leave it fully charged for an extended period of time. IIRC, if it is to be stored for a while, then store it with about 50% (not sure about the exact recommended %) capacity.
    #3 Prius from Dad, Sep 19, 2019
    DD1, Raytheeagle and Justabrake like this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I would not buy a hybrid if i planned not to use it for months at a time.
    phlack and Justabrake like this.
  5. bisco
    52,814
  6. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Yes, you can, but I would check/drive it on occasion to ensure nothing goes wrong.
    While I can understand the logic, if you're a city dweller to likes to get out of town on occasion, a hybrid is as good as any vehicle.
    HOWEVER, do make sure to the run the car regularly (once a week is preferable). I'm pretty certain I killed the hybrid battery on my previous car (a honda civic hybrid) by running down the battery after a drive then letting it sit unused for 2 months.
    Justabrake likes this.
  7. Justabrake
    First I should mention I was thinking about the 2020 prius prime or the RAV4 2019 or 2020 in a couple of months I've had interest in the Tesla but after knowing they lose 2 miles an hour of battery when sitting I don't that's for me I usually park when I go into the city for a week and leave my car for that long without moving it so now i just wanted to get an idea about how that battery would work for me on the prime car
  8. bisco
    52,814
    are you sure its that high?
  9. Justabrake
    some said 2Hrs. others said 1 its a computerized car so a lot of stuff keeps running when parked
  10. Justabrake
    This is why I asked does the battery on these Toyota’s Prius Primes ever loose strength
  11. bisco
    52,814
    i have heard that, but you would think there would be an independent test.
    i haven't heard any complaints from owners here.
  12. bisco
    52,814
    prius runs the electrical system from the 12v battery when the car is off. there is no connection to the hybrid battery.
    the complaint here is 12v drain, so you need a battery minder if you're gonna let it sit.
    you can also shut down skas, which is helpful.
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    As for not driving a Prime for a while, the manual says to use up the EV range and leave it uncharged when not driving for extended periods. It does not give any indication of how long a time would qualify for that precaution. The hybrid battery will not drain to any noticeable degree, because as @bisco said, the HV battery is completely disconnected from the car when it's not in READY mode.
  14. bisco
    52,814
    not something you have to worry about with a tesla, and even after a month, what are you down to, 250 miles of range?
    jerrymildred likes this.
