Question on Water Pump Replacement at 167k Miles?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sdrocker, Jul 8, 2015.
  1. Patrick Wong
    18,214
    6,530
    Yes, Aisin would be a great alternative. I have no problem buying aftermarket if the manufacturer is the same as original equipment.
  2. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks I have the 53 Chevy but I was going to do a disc brake kit upgrade this weekend as well.. to play it safe ill make sure the prius is done first. I remember mention of a thread on how to do the waterpump, including tools. was that one you made? I will search again to see if I can find it.
  3. Patrick Wong
    18,214
    6,530
    There are several places where you may have a problem:
    1. Loosening the nut on the idler pulley. You need a quality 14 mm, 6-point socket. Do not use a cheap 12-point socket because you may damage the nut and make it very difficult to remove. A few posters have experienced that problem. Be prepared to use a breaker bar and cheater extension pipe if needed, to exert adequate loosening torque on that nut. Tightening torque is 30 ft.-lb.
    2. Holding the pump pulley stationary when removing the three pulley bolts. The worn serpentine belt does not exert sufficient friction to hold the pulley in place, so you need an alternate means. I inserted a screwdriver through a pulley hole so that as the pulley rotated, the screwdriver blade was forced against the engine compartment wall which stopped the pulley from moving. There is a tool that you can get to hold the pulley stationary, as an alternative. This tool basically contains two fingers which will be inserted into two of the pulley holes.
    3. Accessing all of the fasteners on the pump - make sure you have the appropriate extensions for your 3/8" socket wrench and a quality 10 mm socket. You also should have an open-end/box-end 10 mm wrench which may help removal of the pulley bolts.
    4. Tightening the serpentine belt sufficiently - the spec is to apply 22 lb of force on the middle of the longest stretch of the belt and the new belt should deflect 0.4".
    No gasket sealant is required assuming you are installing the correct coolant pump which comes with a gasket. I think the gasket is sheet metal coated in rubber.
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    aisin is the oem manufacturer. the only difference is the aisin pump has Toyota ground off the casting. buy aisin, get the same part for less $. reuse your coolant since you just flushed it 3 weeks ago.
    I didn't loosen the tensioner when I did mine. I just stretched the new belt on. it was plenty tight.
  5. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks that is good to know i don't need to loosen the tensioner. I want to change the waterpump tonight. The toyota dealer is open until 7pm and I may go after work and get it. I'm guessing the Asin would cost $40-50 less? I'd be up for that but it may not arrive until some time next week and I want to do my moving and final 53' Chevy hotrod brake work then.
  6. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks so much that is super useful information and I will follow it tonight when I do the water pump.
  7. JC91006
    16,939
    8,647
    here's a video
  8. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks so much!
  9. Patrick Wong
    18,214
    6,530
    I would not recommend this practice, but to each his own...
  10. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks I'll follow your instructions.
    From the Toyota Dealer, the belt is $21, the water pump is $80, the coolant is $20 and the pcv valve is $12.
    Would be nice to save a bit with the asin one on Amazon but I think it's better for me to get this done tonight so I can focus on other things.
  11. Patrick Wong
    18,214
    6,530
  12. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks I agree. I'd have way more to lose if I had to miss a day of work due to a car issue. I'd be ahead of the $300 I would have spent at the tire shop and that didn't include a pcv and serpentine belt.
  13. JC91006
    16,939
    8,647
    If you have a AAA card, you may get 10% off. Just ask
  14. sdrocker
    sdrocker Member
    166
    San Diego
    Oh i didn't know that I will do that. I have AAA thanks!
  15. 69shovlhed
    2,170
    752
    Delaware
    done it many times on lots of different cars. sometimes I still need to adjust the belt tension, but sometimes I don't.
