Question on wire colors verification
Discussion in 'Gen 3 Prius Technical Discussion' started by cobraz, Dec 19, 2016.
  1. cobraz
    cobraz Prius Pirate
    81
    26
    2018 Prius
    The Cig lighter has two wires..
    Blk/Wht and Blk
    I thought Blk/Wht was Positive
    Blk was Negative
    Someone said the reverse - can someone verify the colors for me ?
    Thanks.
  2. ChapmanF
    19,002
    I think I'm the person who said the reverse, so this doesn't count as verification, but, anyway, about that ....
    I eagerly encourage anybody looking to verify such information (which is a very good idea) to check the wiring diagram at techinfo.toyota.com directly. That takes it completely out of being my opinion vs. anybody else's opinion on PriusChat, and relieves you of the trouble of trying to decide which of two or more loudmouth PriusChat members, who are strangers to you, you find more convincing.
    In the case of the two cig lighter wires, of course, you also have a very easy option of verifying with a voltmeter.
    Cheers,
    -Chap
  3. cobraz
    cobraz Prius Pirate
    81
    26
    2018 Prius
    I talked to a mechanic ...
    Blk/WHT is Pos
    Blk is Neg
    It is opposite of Marine or House Hold Electrical
    SAMSUNG-SM-G891A ?
  4. ChapmanF
    19,002
    Try a voltmeter. Or pull off some of the dash trim and observe what color wires are attached to the grounding screws. OR look in the wiring diagram. You've got options.
    Anybody with a current techinfo subscription could post a screengrab here, to make sure this thread doesn't mislead future readers. If mine were paid up at the moment I'd do it, but I like to save up questions so I've got several to answer when I spend the next $15.
    -Chap
  5. Prodigyplace
    12,711
    11,848
    Central Virginia
    Your car is negative ground. The one connected to the outside shell is negative. The wire connected to the center post is positive.
    This is assuming somebody has not reversed them. You need a voltmeter to tell for sure. Connecting the positive to the shell would boiw the fuse.
  6. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    White/Black to ground. See attached.
  7. Mendel Leisk
    42,323
    Yeah if you're working on wiring a multimeter is a must. Plus some electrical basics.
  8. cobraz
    cobraz Prius Pirate
    81
    26
    2018 Prius
    Hey guys thanks for setting me straight on this one.... Blk Pos, Blk/Wht Neg... per wiring doc.
  9. ChapmanF
    19,002
    Glad to help. Still, next time you have a project, don't assume everything follows one simple rule like that. There are a lot of wire colors in these cars. Toyota often uses white-with-black-stripe for ground, but in some circuits (typically involving sensors) they use brown. And they can also use both those colors for other things, and in rare cases some other color is a ground return.
    Always best to take a peek at the wiring diagram before diving into a project.
    -Chap
  10. cobraz
    cobraz Prius Pirate
    81
    26
    2018 Prius
    Thanks Chap.. it's been challenging...next mod is remove grill and add fog lights and new grill and new horns and new h11 lights ....wiring wiring wiring.lol
    SAMSUNG-SM-G891A ?
