Question re: 12-volt battery, please?
Discussion in 'Gen 2 Prius Main Forum' started by Julia2001, Aug 14, 2012.
  1. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I believe so? Try it and see what happens. Be careful!!! <grin> H
  2. Patrick Wong
    18,210
    6,526
    Yes, lock the doors manually and make sure you have the fob.
  3. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Thanks for the update Julia. :)
    BTW. Are you sure that's not the other way around? Normally the voltage measured in "acc" mode should be the higher of the two.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I'm also surprised the battery is not showing a higher voltage.
    Question for the experts: should a 5 hour charge in READY accomplish the same charging as a 5 hour drive ?
    I had earlier calculated the battery nominal capacity at ~ 330 wh. If the battery started at 1/2 full, then it needs ~ 165 wh to fill up. At 13.8 V and 2 Amp, that implies 175/(13.8*2) ~ 6 hours of READY charging.
    I'm confused. Or my arithmetic is wrong. Or the battery has a problem.
    Addendum: A google search found one person who said the Optima has 50 Ah of capacity, thus about 600 wh. If this is correct then ~ 12 hours of charging to top-off may be required.
    Half way there
  5. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    On my 2010, the in-car voltage display shows lower than when I test with my multimeter. Perhaps she and I have a weak ground at the point the car takes its measurement?
  6. hill
    9,041
    I've noticed over the years how slow the synergy drive systems replenish. So with the more powerful Optima, that doesn't sound too horribly far off.
    SGH-I717R ? 2
  7. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Okay, so -- now that I have the OPTIMA battery, is this still a good enough charger to buy for the purpose of topping off my NEW battery, bringing it up to speed, and then charging once a month or so to keep the battery in tip-top condition? And if this is still okay even with the Optima, do I simply set it to 4A and allow it to sit overnight?
    Diehard 6A Automotive Battery Charger - Walmart.com
    Thank you very much.
    Julia
  8. Patrick Wong
    18,210
    6,526
    The voltage on the 12V bus when the Prius is READY will not change whether the car is at 0 mph or 100 mph. Hence there is no need to take a drive unless you need to go somewhere.
    In another recent post I provided a link to a GS Yuasa catalog which shows the Prius battery has a capacity of 46 Ah. I assume the Optima has a similar rating.
    A 2A setting on the charger does not mean that the charger will deliver 2A constant current. It means that 2A is the most the charger will deliver and as the battery charge level increases, the charger will deliver less current.
    The Optima catalog sets the expectation that 12 hours of charging time may be required.
    One or both devices may have measurement error. If you have a quality multimeter, I would tend to trust that more than the MFD voltage readout.
    That is an OK charger and you can use the 4A setting and leave it as-is until the charger tells you that the battery is fully-charged, which hopefully will happen by the next morning.
    Julia2001 likes this.
  9. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you, Patrick.
  10. HaroldW
    716
    95
    Perfect! Go for it. The Diehard 6 amp.H
  11. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Ordered it. Thank you! :)
    So EXCITED to be spending more money to bring my 200 dollar battery up to speed! :ROFLMAO:
  12. Patrick Wong
    18,210
    6,526
    Last Friday in my post #73, I suggested that this would be required. Nice to see you have come to a similar conclusion.
    I recognize that many contributors on this string are Optima advocates. I've bought batteries from my local Toyota dealer on several occasions during the past few years, and in every case the newly purchased battery was fully-charged based on voltage measurement out of the box (12.9V for AGM; 12.6V for flooded lead acid.)
    Now that the MSRP of the Toyota-sourced battery has risen, Optima has become the "bargain" choice so I suppose it will be necessary to charge the newly purchased battery depending upon your local source.
  13. Julia2001
    Julia2001 Member
    290
    32
    Maine
    I really have to wonder why........is it because they have been sitting on a shelf for a long time?
    They should be topping off these 200 dollar batteries before they send them out.
    I have no idea if I have a bad battery, or a used battery or what...I'm trusting them.
    But frankly, at the risk of giving this entire forum a good laugh, I have actually considered RETURNING the battery and buying one elsewhere.
    Go ahead...guffaw. :D
  14. Patrick Wong
    18,210
    6,526
    Doesn't your new battery have a date code sticker or some other means to show when it was manufactured? That is normal practice.
  15. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Yes, it does. It SAYS June, 2012.
    But really...if it was actually manufactured two months ago, shouldn't it read somewhere close to 12.8 out of the box?
  16. Patrick Wong
    18,210
    6,526
    Exactly. The Prius batteries sold by Toyota dealers come from Japan so they have to take an ocean cruise, then go through the US parts distribution system to get to you.
    I would therefore question whether the batteries shipped by the Optima factory are fully-charged.
  17. Julia2001
    Julia2001 Member
    290
    32
    Maine
    So - I did buy the charger, however, I have to ask this question...
    Would you still consider it simply a matter of charging the battery or would you suggest that I return the battery?
    I guess I'm asking if there could be something sub-standard about the battery itself?
  18. Patrick Wong
    18,210
    6,526
    Since you've already installed the 12V battery and purchased the charger, I would suggest that you charge the battery first and see what happens.
  19. HaroldW
    716
    95
    I checked my original on my 06 today and it was at 12.58V I use a 2 amp electronic maintainer ones ever couple weeks or when the car is not used much. Its called a Eliminator . H
  20. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    No, from New Optima Battery DOA (almost); And Getting Worse | Page 4 | PriusChat
    My new battery out of the box read 12.52 volts measured at the terminals (not connected to a car).
