Question re: 12-volt battery, please?
Discussion in 'Gen 2 Prius Main Forum' started by Julia2001, Aug 14, 2012.
  1. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I too agree that the battery is simply not up to full charge yet like Patrick is saying. It would not surprise me if it takes a good 12 to 24 hours of charging to bring it up to 100% charge.
    Sitting on a shelf for 30 days idle in the heat (80 F. or higher) can essentially reduce the charge of a new fully charged battery a good 40% when you consider a 12V battery is considered 60% discharged @ 11.9V and fully charged at 12.6V or higher. Furthermore, when a battery gets discharged, the plates tend to sulfate. Unless you get a desulfator, you may not be able to achieve a complete 100% charge with a regular battery charger.
    Read the following about the sulfation of 12 volt batteries, then you will understand one of the problems with 12 volt batteries. Not all battery charger's will desulfate, only some of them. If you are interested in getting maximum life span and 100% charge out of your 12 volt battery, you might want to consider a charger that also desulfates.
    http://rollsbatteryne.com/docs/A%20Sulfated%20Battery.pdf
    Two chargers that desulfate have been mentioned here on PC
    Amazon.com: Pulse Tech XC100-P Xtreme Charge 12V Battery Maintenance Charger Desulfator: Automotive and BatteryMINDer Battery Charger / Maintainer with Desulphator — 12 Volt 2/4/8 Amp, Model# 12248 | Battery Maintainers| Northern Tool + Equipment. Both of these units will charge and desulfate a battery.
    Ron
  2. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    I'd also mention that many battery chargers cut off before taking the battery to 100% charge as they can't accurately tell when to stop. If you leave the charger plugged up after it says the battery is full a better charger will continue to top up the battery at a much slower rate. Eventually after a day or two on the charger you might get the battery fully charged.
    On a dumb charger you may have to charge it to "full", take it off and let it sit a while then charge it again.
  3. Patrick Wong
    18,210
    6,526
    Good point. This is why I like using a lab power supply to charge 12V batteries, as I can set the charging voltage and maximum current, and monitor the decrease in current over time.
  4. Patrick Wong
    18,210
    6,526
  5. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you all very much for these great explanations and suggestions.
    Julia
  6. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Thanks for the info dhanson865.
    BTW. Now that your battery is just being charged and maintained by the Prius, have you re-measured the (service menu displayed) voltages in "acc" and ig-on" modes? It would be really interesting to see how a random measurement now compares to the values you noted previously for when the battery had just been charged externally.
  7. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Uart, thank you so much for pointing me toward that discussion! Without this opportunity to read through the entire discussion including informative responses from the Optima Battery rep, I would not have known any of this information.
    I do think I have a defective Optima Yellow Top battery. In ACC it currently reads 12.0, then in Ig-On it drops to 11.7 which is worse than my old battery, the ORIGINAL FROM 2007!
    The following from the thread you very kindly pointed me toward is of particular interest:
    FlyboyTR, I'm sorry to hear about the problems you had with your battery. 11.1 volts on a YellowTop is actually more than 90% discharged. Fully-charged our YellowTops will measure about 13.0-13.2 volts, while our RedTops will measure about 12.6-12.8 volts. All batteries will slowly discharge over time and it is always good practice to measure battery voltage before installing it in a vehicle and fully-charge it with a battery charger, if necessary. Whenever a battery is discharged below 12.4 volts and allowed to sit in that state, sulfation will begin to diminish both lifespan and capacity. We haven't heard of any issues on our end, with batteries arriving at retailers deeply-discharged, but I did inform my supervisor of this thread and we will be monitoring the situation closely.
    Read more: New Optima Battery DOA (almost); And Getting Worse | PriusChat
    If I had not already brought my old battery to Advanced Auto for recycling, I would return the Optima and reinstall my old GS battery. Frankly, I wish I'd never changed it to begin with...caused myself a lot of headaches...and now 250 dollars in expense....that I did not need. Needless to say, I'm not happy with my first Optima battery experience.
    And I want a new battery.
    usnavystgc likes this.
  8. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Harold, in retrospect frankly I wish I'd have done the same....just KEPT my original battery and purchased a charging unit to keep it healthy. It would have been FAR less hassle and expense.
    I say this not to whine, but to alert those in a similar situation.
    dorunron and usnavystgc like this.
  9. bisco
    52,863
    julia, is your car starting and running okay?
  10. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Yes. As it was before I dumped the original battery for the Optima. No improvement, no apparent issues.
  11. Julia2001
    Julia2001 Member
    290
    32
    Maine
    FYI....For anyone who may need the information now or in the future, this is direct information from the Optima Battery representative:
    "We recommend a maximum of 10 amps for up to two hours, which should get the battery close to fully-charged (if not all the way there). Any amperage below that should be fine as well, provided the charger has some regulation to prevent overcharging. Fully-charged, it should measure about 13.0-13.2 volts."
    Read more: Optima DS46B24R Prius Specific 12v. Battery | Page 5 | PriusChat
  12. Julia2001
    Julia2001 Member
    290
    32
    Maine
    This is what has me most concerned and wanting a new battery. From the Optima rep:
    "Whenever a battery is discharged below 12.4 volts and allowed to sit in that state, sulfation will begin to diminish both lifespan and capacity."
    Read more: Question re: 12-volt battery, please? | Page 11 | PriusChat
  13. dorunron
    3,318
    1,105
    Houston, TX
    Julia,
    You may find that if and when you get your next battery, you will have better results if you do a couple of things before installation.
    Try these steps the next time, and you might have better luck. First and foremost, never place a battery on concrete, as that will kill a battery quick. If you have to put the battery down, place it on a metal shelf or a block of wood. Do not set it on concrete at any time.
    Check the voltage of the new battery, and if it is not fully charged place the battery on a charger and charge it until the battery is fully charged, usually overnight. Then let it rest twelve hours. After that check the voltage again. A 100% fully charged 12 volt battery should show at least 12.6 Volts or more. If the battery was severely discharged (new), it may require more than one charging session to achieve the 12.6 desired volts. Have patience with battery charging as it is a slow process overall.
    Once the battery is fully charged, proceed to clean all connections. Use a battery post cleaner, and clean both the post's on the battery and the terminal clamps that go on the post. The prius battery has small posts, so you will find it tricky to clean them with a standard brush from your auto parts store. A wire brush like a welder uses is very helpful when cleaning the post and the standard brush from the auto parts store will clean up the clamps. Once all connections are clean, and the battery is charged to 12.6 Volts, then proceed to install the battery.
    I think if you will try these things the next time you go thru changing a battery, you might have better end results.
    I am sorry to hear you think the Optima is bad, it could very well be. I do understand your agravation, I too would be unhappy if I were in your shoes.
    Finally, if I were you I would invest in a good battery charger for future use. You seem to know about the sulfation already, therefore you might consider getting a charger that also desulfates.
    Good luck and I hope the sun shines a little brighter for you.
    Ron
    Julia2001 likes this.
  14. usnavystgc
    3,159
    990
    Tucson, AZ
    Julia,
    Sorry you feel that way. I see this as a situation where too many hands spoiled the soup. I wanted to tell you to keep your old battery and not buy a new one but, I really didn't think I would be heard. There were so many people tripping over each other to help (which is great on one hand) that it would have been impossible to decipher who had the best advice. I just felt like it would have just added to the confusion to post my $0.02. I would never have predicted this would have happened. Keep your chin up and don't spend any more money on this battery. If it fails w/in the warranty (which I don't think it will), take it back. I wouldn't buy a minder, charger or anything else. Let it fail and get some warranty coverage.
  15. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you, Sir. I appreciate your post. It's hard when there are folks in the know who are saying your battery is about to fail...replace it now. And you've got a Maine winter ahead of you, to top it off! I thought it was good advice to be proactive, rather than find myself somewhere requiring a jump start, and finding myself thereafter replacing my battery in the cold winter months. So...I made a choice, and only I am responsible for it. I regret it, yes. But I still think the advice offered was sound advice and I do appreciate it. Little did I realize, however, that simply keeping my old battery and charging it every so often was EQUALLY good advice!
    Ah, hindsight.
    Thank you very much again for your thoughts and your support.
    Julia
  16. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you so much, Ron. I appreciate these tips as well as all of your help throughout the process.
    Julia
    dorunron likes this.
  17. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Come oooooooon Ron. Seriously, if you look up "old wives tales" in the dictionary that's probably the definition. There is no harm at all in placing a battery on concrete .
    The only merit at all to that story is in extreme cold conditions, where placing the battery on a piece of wood will somewhat help in preventing it from freezing.
  18. bisco
    52,863
    it won't start or run any better if your old battery was okay, so i would say this one is okay too. but if it's not upto specs for a new battery, i suppose optima should replace it under warranty. advice about replacing good batteries after 4-5 years is to prevent sudden failure. the life of any battery is unpredictable at best. i still think replacing it was a good idea, just not the best results.
  19. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you very much, bisco. I appreciate your response. Makes me feel a bit better about the cost I've put into this endeavor. I still want a new battery. I feel I should have received a battery in tip top shape, not one that has been discharging and sulfating, thus being received by me with a diminished lifespan and capacity, according to the Optima representative himself:
  20. Patrick Wong
    18,210
    6,526
    Hi Julia,
    Before you go to the trouble associated with removing and installing yet another battery, I strongly suggest that you fully-charge your current battery and see what happens. If your battery shows good voltage at that point then why worry?
    Suppose your retailer had checked the battery voltage and charged the battery as you had requested, before selling it to you. You would have no idea what the voltage was prior to its being charged.
    If you ask for a replacement battery, the retailer will put the replacement on a charger, before giving it to you. What is the difference with that process compared to working with the battery you have installed in your car and charging it after the fact?
    PaulHS and HaroldW like this.
