Question re: 12-volt battery, please?
Discussion in 'Gen 2 Prius Main Forum' started by Julia2001, Aug 14, 2012.
  1. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Julia2001;
    Once you get the new 12V you will be fine. I would not loss any sleep over it. Those devices are expensive and you may never need to use it and if you do have to, it probably wont work anyway. Made in China!!! Your Prius is very reliable auto. :)
    Cheers, H
    Julia2001 and usnavystgc like this.
  2. alekska
    alekska Active Member
    435
    138
    Atl
    Or, rather, charged.
    - Aleks
  3. alekska
    435
    138
    Atl
    Or, you can get a solar panel, hook it to the battery directly, leave in the trunk under the hatch window (or, better, on the roof between rides) and have it charged by Sun!
    - Alex
  4. Julia2001
    Julia2001 Member
    290
    32
    Maine
    I cannot find the year and month sold anywhere on the battery, but thank you for the suggestion. I would love to know if it is the original battery!
  5. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Will I need to do these things even if I buy a new battery? Buy a battery charger and charge my battery twice a month??? Or a Battery Minder?
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Low mileage & short trips are tough on every car's batteries. Do you have to trickle charge the battery? No. But it will die sooner than if it is.
    Your battery will work fine. One day you'll approach the car & the lights won't come up. You'll manually unlock the door, insert the fob, and the car won't start. Maybe it will start on the 3rd attempt.
    Now you'll need a jump. Horror stories happen because people don't pay attention to what they are doing. Reverse the polarity on any other car & you'll cause damage too.
    Swap out the battery at your convenience or do it when you need it. It's up to you.
  7. HaroldW
    716
    95
    If you find the new 12v is only showing 12v or less just do what I mentioned earlier. When you park your car leave it in park and the ready light on. The car will charge the 12v in a couple hrs. The engine will start off and on that is all. You should only have to do this if you have many short runs. Like I said early on, don't worry so much about it! H
  8. Patrick Wong
    18,210
    6,526
    The original equipment battery is made by GS Yuasa. The date code is on top of the battery and is hidden by the battery bracket.
    Yes, if you want your new battery to be maintained in top condition. Alternatively if you don't take some action to periodically charge your battery and continue to drive 6K miles per year, your new battery will deteriorate over time and eventually fail.
    Well, I would say that if you leave the car READY overnight (in other words, for 8 hours or more) then the 12V battery which is near-discharged probably will become charged. 2 hours is not enough time.
  9. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you all very much.
    Two more questions: If I buy the yellow Optima battery, is that a DIY project that I can do, or should I take it over to Toyota and have the battery replaced?
    Also, can you please recommend a particular Battery Minder that is good for my 2007 Prius, a battery charger, and/or a portable boost pack? I'm just asking for what other members have used that work well for them.
    I know I wont want to leave my car on all night long twice a month!
    I don't want to hook the battery up to something night after night either, and frankly had I known about all of this nonsense I probably wouldn't have bought this car, as much as I love it. But the car is mine now and I have to deal with this apparently, so I would appreciate knowing which products work well for other Prius owners.
    I just said to someone the other day that I am a Prius-for-life girl now...and I talk the cars up to friends buying cars all the time. I hate to whine, but frankly working mothers who already have so much on our plates don't really need another thing to remember in order to keep ourselves from being stuck needing a boost from AAA (who probably can't even boost a Prius safely I now learn! So much for AAA as peace of mind!)
    Any guidance as to the particular products to buy would be very much appreciated.
    Thank you all for educating me.
    Julia
  10. Patrick Wong
    18,210
    6,526
    Hi Julia,
    Regarding your question about whether this is something you can do, there are many posts about how to replace the battery. If you have 10-12-14 mm sockets and open-end/box wrenches then you will have the needed tools. If you can physically lift the battery, then no worries.
    I personally would recommend using a battery charger instead of a battery minder, because you then only have to worry about hooking up the Prius to the charger once or twice per month (rather than connecting the minder daily). It is easiest to do this via the main relay/fuse box next to the inverter.
    Open the hood, find the relay/fuse box, press hard on the latch at the front of the box lid, then pivot the lid up and remove it. Find the red plastic cover over the dedicated positive jump start terminal and pivot that open so the terminal is exposed. That is the positive terminal.
    Find an unpainted metal piece on the body, for example, one of the nuts that hold the driver's side front strut mount to the body, above the relay/fuse box. Use that as the negative terminal. Hook up your battery charger to those terminals, set the charger so that the maximum charging current will be 4A, turn it on, and then you are good.
    Regarding what kind of charger to get, you want one that has a current meter on it so that you can see exactly how much current is being produced at any moment in time. Then you can check on the car periodically, for example at the two hour mark, and see how much current the battery is still taking.
  11. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    I've had good luck with the BatteryMinder Plus. It is 2A max, I believe, but each of my cars gets to full charge in a few hours. You can do it once per month or twice, or not at all. You have never done it, still get decent fuel economy which may not improve at all with new or charged battery, and your battery could be 5 years old. So, don't sweat it.
    By the way, I tend to defer to Patrick on any maintenance issues. So favor his words over mine. Just sharing my experience.
  12. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you, Patrick. I will research those specs. Meanwhile, if anyone has a link to this type of charger I would appreciate knowing of a good one. I'm guessing we are not talking about a portable jumping thing that I can also keep in the car to jump a battery in an emergency but that would seem to be ideal.
    I'm also guessing that I will need to keep that charger charged by keeping it plugged in somewhere safe?
    Off to read battery installation instructions to determine my level of self-confidence.
    Thank you again for your generous guidance.
    Julia
  13. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you very much!!!
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    elearnaid sends a six page manual with the battery, it is summarized here:
    Optima DS46B24R Optima battery direct fit replacement for Prius 2004 +
    They also sell a 0.9 amp charger
    AccuMate 12 volt or 6 volt battery charger for sealed or regular batteries
  15. Julia2001
    Julia2001 Member
    290
    32
    Maine
    I'm reading that many cables don't attach well to the Prius battery post.
    If anyone has a specific unit that they use which works especially well for the Prius by design of this feature, I'd greatly appreciate a link to the product.
    The good news is that I have the tools available to install a new battery. That bright yellow Optima is the best, is it?
    Or is it hype?
  16. Julia2001
    Julia2001 Member
    290
    32
    Maine
    So wait a minute....I can use a BatteryMinder Plus to keep a good charge on my new battery by only hooking that up to my battery once or twice a month??
    Also...this product would work the same way? Seems the least expensive way to go...
    Sufficient?
  17. Julia2001
    Julia2001 Member
    290
    32
    Maine
  18. ksstathead
    1,244
    245
    Kansas
    The batteryminder I see at amazon is 1.33 A for $44. I think it is the same as mine.
    I don't know about the .9 A accumate you reference for $33.
    Patrick's 4A suggestion is best, but surely any would work, substituting time for cost savings.
    It is not like you fully deplete your battery. It just needs a little love to offset your low mileage/short trips. Same would be true with any car, except alternator cars usually charge more aggressively when running, so not as noticeable.
  19. ksstathead
    1,244
    245
    Kansas
    That's a good price, but I don't know if it is a good charger.
  20. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That Optima has the Japanese type battery posts so the cables in your Prius will fit fine. Most other car batteries sold in the US have the larger SAE battery posts and the cables would have to be adapted. I have the DS46B24R in my 2004 Prius and it went in with no problems.
    JeffD
