Question re: 12-volt battery, please?
Discussion in 'Gen 2 Prius Main Forum' started by Julia2001, Aug 14, 2012.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I just replaced mine also last weekend with a brand new Yellowtop. I put it on a charger before I installed it and it was pretty low. Took about 1 hour to charge it up in 2 amp mode. Who knows how long they sit on the shelf before you buy them and they don't charge them before selling them.
    You need to buy a regular charger not a battery tender. One with a analog charge rate meter not led's. I just picked one out for a buddy last week This one:
    DieHard 10/2/50 amp. Automatic Battery Charger - Automotive - Battery Accessories - Battery Chargers
    It has a 2 amp mode. On a healthy battery once a month in 2 amp mode will bring the battery to full charge in less
    than 20 minutes. Do that once a month and you should exceed the yellowtop 5 year warranty.
    Plus its the best battery troubleshooting tool there is. When you hook the charger up notice how much of an initial current draw is on the charger and notice how long it takes to reach a full charge. When you see those 2 events change your looking at an unhealthy battery. That's how I knew my original was going south. That battery lasted exactly 5 years almost to the day with monthly charges all its life.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    A couple of dumb questions if I may:
    1. Do you mean initial current draw from the battery ?
    2. Is full charge set to a voltage or capacity ? How much ?
    Thanks
  3. Julia2001
    Julia2001 Member
    290
    32
    Maine
    What makes me angry is that I ASKED them to check the voltage and if it wasn't up to snuff, to put a charger on it.
    Now I am going back down there in angry mode because they patronized me and laughed at me for suggesting that a brand new battery might not be at full voltage capacity...and I am going to tell them that now I need to BORROW a charger from them to charge it up.
    And I will, at a later date, buy a charger...BUT NOT FROM THEM!
    By the way....the battery I replaced WAS the original battery (reminder, I drive a 2007) and was working nicely still! Just as well as this one, in fact! Even will my meager driving routine.
    Thanks for the responses.
  4. edthefox5
    10,096
    4,840
    Clearwater, Florida
    1-Yes
    2-Capacity. Full charge is when the battery will not take anymore charge. Meter shows O current draw.
    Elapsed time on how long that takes is important too because that shows beginning of sulphation.
    A healthy battery that's just a little low will charge up very fast. Over time as electrolyte wears out it takes longer and longer to reach O draw. And if its getting real bad will never become fully charged. It will always show current draw Time for a new battery.
  5. edthefox5
    10,096
    4,840
    Clearwater, Florida
    SORRY
  6. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Haha. I wasn't yelling at you, Ed! I'm mad at the Advanced Auto dudes!
    Thank you for your very good advice.
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    The new battery sounds like it has a partial discharge and needs a recharge to full. If I didn't have a battery charger at home, I'd just let the car do the job by letting the car sit for some 4-6 hours in ready mode.
    I'm of Julia's mind -- I'm more inclined to buy a new battery more often than to have a good maintenance routine that extends the battery life. In my case this is because I am not comfortable fooling around with electricity (although I want to learn,) and more importantly because the car is not garaged.
    HaroldW likes this.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Thanks Ed.
    I'm still unclear about (2). Do you set the charger to an amp-hour rating, or does the charger simply stop sending current when the voltages of the battery and the set-point of the charger are equal ?
    I may be *way* off track here -- is this fluid analogy correct ?
    I think of amps as flow rate,
    Voltage as pressure,
    and the battery as a closed container
    The charger opens flow into the battery with a pressure of 12v at a rate of 2 amps. When the battery is full enough it has a pressure also of 12v, and flow stops.
    Is this at all right ?
  9. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Just turn the dial to 12v . Some meters don't have 12v in the d/c test area. If it has 6v use that and double the reading? You can also do what SageBrush suggested. Less hassle than trying to borrow a charger. H
  10. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you, Harold. It doesn't read that way unfortunately. On the black V- side it has 2m, 20m, 200m then 2, 20, 200, 600.
    On the red V~ side it reads 200, 2K, 20K, 200K, 2M, 20M, 200, 600.
  11. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you for your idea, Sage.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    I'd like to see a picture, I have to learn this, too.
    I imagine the 'm' stands for milli, the 'k' for thousandths
  13. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Okay I've got it. And I tested my "old" battery and the brand new one.
    Old, original Toyota battery: 12.48
    Brand new yellow top Optima battery: 12.38
    Looks like I should have just kept my old battery!!! This would be comical we're it not so frustrating. ;)
    The Advanced Auto guy lied to me. He wouldn't have been as likely to lie to a man making the same request. Just sayin'...
    Advanced Auto gets no more business from me.
    Thanks again for the help, friends.
  14. Julia2001
    Julia2001 Member
    290
    32
    Maine
  15. SageBrush
    11,627
    2,533
    Southwest Colorado
  16. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Last question....my reason to keep the old battery?
    Thank you all again.
    Julia
  17. Julia2001
    Julia2001 Member
    290
    32
    Maine
    That should read ANY reason to keep the old battery? Sorry
  18. bisco
    52,863
    nope, find a place to recycle.
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    I gather some people make bombs of them ;)
  20. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you very much.
