Question regarding Plug in EV Range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 777zbr, Oct 22, 2013.
  1. markabele
    5,084
    1,782
    Nebraska
    I assume just like the gas tank it is a bit pessimistic on it's estimations. My experience is somewhat similar.
    52,849
    yes, i typically go further than the estimate, so i'm not sure what else is involved. maybe they keep it artificially low so you won't run out of electrons. or perhaps it's devalued by temp.
  3. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I get keeping the miles remaining artificially low so you don't run out of gas but EV estimated range ?
    That one seems easy - average recent drives maybe a bit more weight to most recent...
    On a plus note my 2nd tank just exceeded my first tank of 4330 miles. Almost 4400 with 2 gas bars left now
    One fill-up from March through Dec .... amazing car
    retired4999 likes this.
    52,849
    that's crazy!!!(y)
  5. markabele
    5,084
    1,782
    Nebraska
    Nice!
    Where do you live? Will be interesting to see if you can get by with no heat this winter.
  6. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I go considerably less than the estimate under most conditions. I think that the EV mode does great if you are in stop-start conditions. If you just want to go out and drive a set distance, and the route includes anything like hills or speeds above ~40mph, you are going to have a hard time exceeding the estimates.
    Fortunately most of my trips on EV are way less than the total capacity, so the end effect is that it doesn't matter much to me. I just need to plug in a little more frequently.
    Lourun likes this.
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    -8°F here this morning.
    Today's 17 mile commute logged 9 miles as EV.
    128 MPG was the end result.
    markabele likes this.
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    -3°F Here this morning 2.7 miles to coffee
    return home from coffee 3 hours latter, 5 degrees f 2.7 miles.
    Trip all EV 5.4 miles. no ice, heat set LO, fan speed 2 bars.
  9. markabele
    5,084
    1,782
    Nebraska
    3 hour soak near 0 didn't make the ICE come on?
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Nope!
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    Down and up a good size hill too. 48 mph. in a 45 zone.
    I did use 7.3 miles of EV range. :eek:
  12. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    No heat at -2 your either very tough or nuts!
  13. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    I walk 10 feet for my coffee!
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep! they are really cold!:eek:
    fortytwok and markabele like this.
  15. markabele
    5,084
    1,782
    Nebraska
    You do realize that even on a 2 seat V8 truck you wouldn't even get heat in 2.7 miles right?
  16. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    I'm not so sure about that!
  17. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    And at -3 I think I would pre heat car, screw the milage, that's tongue sticking cold!
  18. retired4999
    2,652
    627
    Eau Claire, Wi.
    You might get some but it sure would not be much!
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    Thats why my tongue is so short? o_O
  20. retired4999
    2,652
    627
    Eau Claire, Wi.
    I drive out of a 45 degree garage, drive fast to coffee, hold breath and run into Hardee's! Spend three hours warming up and repeat trip home, but car is alot colder going home!
    I'm purple all over from holding my breath........... or is it the cold temps? :whistle:
