Question regarding Prius and leaving Ac on overnight in Florida
Discussion in 'Prius v Main Forum' started by Davsey27, Jun 25, 2023.
  1. Davsey27
    Davsey27 Junior Member
    25
    I hold.the break and then perry light goes from green to orange and I just see check engine light on dashboard
    This was after running the Ac while asleep for 4 hours
  2. Davsey27
    25
    Thinking of showing up to the dealer later this morning and surprising them with a police report
  3. daisy555
    daisy555 Senior Member
    1,715
    709
    CT
    I would suggest posting in the Prius V section of this forum. This is the 2023 Prius area of the forum but obviously someone will respond. Maybe you already did.
    I personally attempt to get ann idea of what might have gone wrong before approaching dealer although if they are open today, I would be sure to call them.
    Plus look up consumer protection laws for car purchasing in Phoenix. I live in CT and pretty sure a used car dying the next day would be covered unless it was abused in some way.
  4. Davsey27
    25
    In Arizona there is no cooling off period
    It was bought used at 97k.The salesguy even let me take it to a mechanic shop I chose and the mechanic said the battery was fine
    No codes came up
    And was told I could leave the Ac running while asleep
    Sales guy texted me saying he will get someone to tow it and have a look at it at the dealer
    daisy555 likes this.
  5. bisco
    51,932
    Codes only show up after you get the engine light, so they will find them now.
    Are you sure you didn’t run out of gas?
  6. bisco
    51,932
    First thing to do on a 2012 with a hundred thousand miles is clean the egr circuit so you don’t blow the head gasket
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,150
    6,307
    Texas Hill Country
    Wow. Too bad you did not ask first. A 2012 v has a load of potential issues after 11 ten years of use.
    1. Did the car stop on its own?
    2. Hold the keyfob to the Power switch and then try it.
    3. Check gas level.
    4. Check codes. Possible overheating in one of the two cooling systems.
    Return it especially if it cost more than $9k. It is an expensive car to fix down the road. Using it for sleeping while running is not safe and is not good for the engine.
    Common issues you will see over the next few years: HV battery replacement, inverter coolant pump, engine coolant pump and or brake by wire (brake booster) system fail. Head gasket failures are common especially using it like this. Well over $10k in repairs if a good independent hybrid shop is used.
    Other upcoming issues include oil consumption and excessive carbon buildup in valves, intake and egr. The egr is close to $1000 to clean at a dealer. Inverter failure can strand you and is a possibility tight now. Toyota may cover an inverter issue for another two or three years.
    This car is not an allergy solution or a home.
    #27 rjparker, Jul 1, 2023
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,802
    2017 Prius c
    He DID ask first.......sort of.
    And ignored every bit of advice that his plan might not be a good one.
    Bottom line, I think:
    His powers or reasoning are SERIOUSLY lacking if he thinks anywhere in Florida is
    good for someone with severe mold problems.
    And if he thinks using a vehicle in a way that is was NOT designed for is a good idea.
    Especially one that old.
    Doug McC likes this.
  9. rjparker
    10,150
    6,307
    Texas Hill Country
    This was in the gen5 forum until his last post. Gen4 or Gen5 is a different story than a 2012 gen3.
  10. Davsey27
    25
    Now I'm concerned with the emf in this vehicle
    daisy555 and bisco like this.
  11. sam spade 2
    7,035
    2,802
    2017 Prius c
    And I am a bit concerned that you might be spinning a "story" here.
  12. bisco
    51,932
    and well you should be. and in any vehicle or even a home electrical system for that matter
  13. rjparker
    10,150
    6,307
    Texas Hill Country
    I would not worry about emf since most of the power is dc and shielded. Strong emf comes from ac power which is limited to the shielded inverter under the hood and the shielded transaxle under the inverter. More emf in a house, much more under high voltage power lines.
    What did the dealer do to fix the car?
    daisy555 and Davsey27 like this.
  14. daisy555
    1,715
    709
    CT
  15. Davsey27
    25
    Hello rj,
    Essentially they just changed the battery after they towed in.It was fixed same day
    The smaller battery
    Apparently sleeping in the car overnight for 4hrs with ac running did something to the battery
    Regarding the emf.I spoke with lessemf,a company based in NY
    Lessemf.com
    They said they reccomend less than 2.5 MG[MilliGauss]
    Trifield meter would measure this
    It's about 180 for the meter
    If it's greater than 2.5 mG they said people can use material to shield the ground
  16. rjparker
    10,150
    6,307
    Texas Hill Country
    The 12v battery was just bad. Nothing to do with car camping. Unless you shutoff the car in the middle of the night but left things on like lights or the blower.
  17. Doug McC
    Doug McC Senior Member
    1,079
    418
    Midwest
    2022 Prius
    Perhaps the OP may want to reconsider Florida: They will soon be using radioactive materials in their roadways. I find it interesting that the OP isn’t concerned about the phosphate production waste being dumped in Florida’s water ways; the Level 4 hurricanes; etc, etc. and while we’re at it, skin cancers.
  18. daisy555
    1,715
    709
    CT
    Sometimes we have to prioritize and control what we can. I could never live in Florida for a number of reasons but if I was there right now I would be stuck due to limited resources.
    I would love to move somewhere warmer but disabilities etc. can really put a damper on options/choices in life. There is housing for people with multiple chemical sensitivities, severe allergies and EMF sensitivities but it’s scarce and has long waiting lists.
    I hadn’t heard of the radioactive materials being used in roadways. Yikes…what next!
  19. Davsey27
    25
    So no problem running Ac while sleeping at night as this won't do the same thing to battery ?
  20. bisco
    51,932
