Question to the Prius members
Discussion in 'Gen 2 Prius Main Forum' started by Zerokul, Mar 22, 2021.
  1. Zerokul
    Zerokul New Member
    Winston Salem NC
    I will be buying a gen 2 prius from a family friend in April (with a friend discount). The car has 125k miles and a dead 12v battery. The owner mentioned that it could use an oil change as well. I am a pretty good mechanic, but never looked at hybrids since they were a tad more than I was comfortable working on.
    I plan on getting a battery swap (not sure if I want to do the optoma yellow, or OEM, or AGM with lead swaps), and taking it through a quick drive through oil change and head down home (460 miles).
    Any warning signs I should be looking for? I will be limited on the tools I have since I will be flying in and borrowing hand tools from them to get the job done.
    Any wisdom is appreciated. I thank you all in advance.
    privilege likes this.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    How long has the vehicle been sitting unused; days, weeks, months?
    There is a possibility that the HV battery has gone south from sitting too long.
    Raytheeagle, strawbrad and bisco like this.
    52,857
    there are a lot of things on a 13 year old hybrid to be concerned about.
    #1 is, who is going to repair it?
    edthefox5 and Raytheeagle like this.
  4. Zerokul
    Zerokul New Member
    Winston Salem NC
    Weird. I thought I replied, but i can't see it for some odd reason.
    I will update the adventure as I get closer.
    I have a backup plan to get it transported back after I fly for the title and if I fail to get it running
  5. bisco
    52,857
    well that's good to hear
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Zerokul and Isaac Zachary like this.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The correct 12v battery has the small Japanese terminals and is typically carried in stock by NAPA and "Batteries + Bulbs", which are both nationwide.
    Duracell Ultra Platinum AGM Battery for 2008 Toyota Prius L4 1.5L Smart Key 325CCA Car and Truck - SLI51PAGM at Batteries Plus Bulbs
    https://www.napaonline.com/en/p/NBP9851P
    Just about anything you'll need to work on can be done with a 1/4" drive ratchet and a set of metric sockets. 8mm-14mm. And the 10mm/12mm will cover 90% of that. An impact driver with a 1/4" drive adapter makes life even easier.
    Throw a new/good 12v battery in it and hopefully it fires up. Then force charge the HV battery for a couple minutes.
    Zerokul likes this.
  8. Mendel Leisk
    42,349
    Or just drive it and see how it goes? Is there an inherent advantage to force charging? If it involves high revving a long-cold engine, maybe a gentle drive is better.
  9. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    An old hybrid can either be a loveable piece of wonderful money saving technology or a money eating unreliable nightmare depending mainly on who you have work on it and what purpose you plan on giving the vehicle.
    If you're mechanically inclined I'd say go for it and use this forum to help you with the hybrid side of things. It's not rocket science. Just be cautious and you and your car should be fine. Personally I recommend taking every safety precaution just because you can and it won't hinder your work nor cost very much anyway.
    • The HV battery will start acting up some 12 to 15 years after the car was new. With a few tricks you can get a few more years out of it when it does start going bad. A new OEM battery is expensive but will get you another 12 years. http://www.newpriusbatteries.com/ are a little cheaper and seem to be pretty good too. I'm skeptical of just about everyone else that sells Prius Batteries.
    • The next most expensive thing that might go out is the brake actuator. I'm actually a proponent of having the brake fluid changed regularly because of this. In fact I'm getting my brake fluid changed at a dealer this upcoming Monday.
    • Another problem is catalytic converter theft. In some states your only option is an OEM cat which can cost some $1,700 to over $2,000 for just the cat. If you can and don't mind having an aftermarket cat you might even want to change it out. The OEM cats are so full of precious metals that you usually get paid for the cat swap. But if you live in certain states or you want the best emissions possible you might want to be weary of cat theft and add a few deterrents.
    • Old Toyotas are known for their burning oil, and the Prius is no exception (which also clogs catalytic converters). The best way to avoid this is to just do frequent oil changes (every 6 months or 6,000 miles, whichever comes first) with the recommended oil. Avoid parts on the web that could be counterfeit and don't use any thicker or thinner oil or "high mileage" oil or "high zinc" oil or diesel oil or such unless you're trying to bandaid a problem that's already there. I know that a lot will disagree with me and have their reasons for doing so, but I'm convinced that a lot of these Toyotas would not have the oil burning problem they have now if owners just followed this simple advice.
    #9 Isaac Zachary, Mar 23, 2021
  10. Socal_Prius
    Socal_Prius Junior Member
    36
    Santa Barbara, CA
    Sound advice, an OEM 12V is the only really option and they're warrantied for practically the rest of this cars life.
    I will say that in addition to this, if you don;t plan to drive this more than once a week this will have compounding issues as so many Prius suffer due to a failing battery pack triangle of death)) due to leaving it undriven--there are lots of chassis going to the junkyard because of this wave of cat thefts.
    Also, take a look at the rear area where the 12v battery is and see how much water and rust there is, because that could short a lot of things and create a premature death of the car.
    Other than that, just do as much reading here and watching youtube videos and you can get up to speed.
    Isaac Zachary likes this.
  11. Aegean
    Aegean Active Member
    464
    209
    Alexandria VA
    The second gen Prius has few common things that give problems. The good news is that they are so common that there are many threads here to address any of these.
    HV battery
    Water pump, 3-way water valve and inverter pump
    Brake actuator
    Wheel hub bearing assembly
    Combination meter
    AC condenser
    Transaxle is indestructible and engine can last 400k miles!
  12. Zerokul
    Zerokul New Member
    Winston Salem NC
    Thank you all for the valuable info. I am planning on doing the work myself and I will return with news.
  13. The Lizard King
    89
    56
    Assuming that it's Toyota OEM, put some money into protecting your catalytic converter. If you don't, it will be stolen.
  14. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    Don’t forget the multifunction display and potentially stolen catalytic converter
  15. privilege
    privilege Active Member
    659
    169
    Birmingham
    take (or have shipped there) yhe tools you need for
    battery change
    oil change
    12v booster /jump pack
    air fresheners
    air gauge
    if it's been sitting a long time expect:
    dead battery
    dead rodents
    rodent damage
    dead tires
    rusted brakes
    I would drive around town as soon as it was running, do an oil change and put new tires on it. nothing makes an old car feel new again quite like the tires
    if you heavily spray wax the front bumper/windshield it will make clean up a lot easier from the road trip.
    fly n rides (motorcycles) are the most fun ever.
    fly n drives a fun too, you just miss some of the elements of adventure
  16. Zerokul
    Zerokul New Member
    Winston Salem NC
    Thanks! I am limited on the amount of tools I can take (personal back pack only on Spirit airlines).
  17. Zerokul
    Zerokul New Member
    Winston Salem NC
  18. Zerokul
    Zerokul New Member
    Winston Salem NC
    Just got the car home. Working through some evap codes, flickering head light and front brakes.
    Fantastic gas mileage and comfortable to drive!
