Question
Discussion in 'Gen 2 Prius Technical Discussion' started by JerryMcG, Nov 6, 2017.
  1. JerryMcG
    JerryMcG New Member
    Independence, MO
    I bought an ECM but it didn't solve my issue. I'm wondering if you can help. Dealers only want me to bring it in. The issue I am having is that it drives fine but then the red triangle with the explanation point comes on. And as long as I turn on the air or heater to keep the motor running, well it will still drive, But the second the engine stops it is dead on the road. What I do then is disconnect the negative battery cable for a few minutes, rehook it and then it starts and runs. I thought the computer was bad so I replaced it. What do you think the issue is? I can do my own work but this prius is not like a normal car. Can you help or forward this to someone who can? Or connect me with someone who can? Any help would be appreciated. Thanks
    52,804
    welcome!
    how else can the dealers diagnose the problem, over the internet?
    you need a prius aware scanner to find the trouble codes.
    how many miles on her? sounds like your hybrid battery might be going.
    Raytheeagle and valde3 like this.
  3. Prodigyplace
    12,711
    11,848
    Central Virginia
    Your dealer has the software Toyota recommends to read the Prius-specific trouble codes.
    Only with those codes will we have an idea what is wrong.
  4. JerryMcG
    JerryMcG New Member
    Independence, MO
    Yeah I'm aware they have to have it in their shop to "diagnose" it. I don't like shops. But the battery was replaced 2 years ago.
    It has about 160,000 miles. I'm interested in finding someone that has had the same issue and fixed it their self.
    I'm not made of money, which is what the shops want. Plus I like to work on my own vehicles. It's not my only transportation either.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Well Jerry, there's about a million things that COULD be causing your problem. Guessing would just be wasting everyone's time. Do you have a laptop? If you do, then go on ebay and purchase the mini-vci cable/connector and techstream software for 30 bucks or so. That will allow you to go online with the car, so you can get the actual codes and subcodes which will help localize your problem. How much did the ECU cost? What's your time worth? How many other parts do you want to swap out following guesses? There's a lot of smart guys here with a TON of experience with Prii. Even they need a starting point to not waste time, money and effort.
    How was the battery replaced? A craigslist rebuilder, or a Toyota facility?
    #5 TMR-JWAP, Nov 6, 2017
    valde3 likes this.
  6. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    You can get your own code reader and copy of Techstream or Techstream Lite to diagnose trouble codes. Doing that the official way Toyota recommends would be more expensive than getting a shop or dealer to diagnose the codes on your car - it costs $500 for the Mongoose Pro they recommend, and Techstream itself has a yearly subscription cost of $500 or more. Alternately, there are much less expensive options that should work. VXDiag Nano is only $80, for instance.
  7. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You are about 500 miles away from the best G2 Prius independent shop - Prius hybrids sales and service Scottsburg Indiana
    JeffD
  8. JerryMcG
    JerryMcG New Member
    Independence, MO
    I hear you all and thanks for the replies. I'm not trying to guess and waste money on parts. I guess I will figure something out. I will give myself a little more time then....go to the damn shop.lol
    Raytheeagle and bisco like this.
  9. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Jerry, I'm being serious. If you are going to own a Prius, and plan to do your own maintenance, you really need to think about getting techstream. At the very least, if you have an android phone, get some free apps like Torque or Hybrid Assistant and an OBD Bluetooth adapter so you can at least read the hybrid codes. Otherwise you are purchasing a ticket for the pain-train.
    Prodigyplace likes this.
  10. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Maybe you should DO that.
    How much money (and time) have you wasted on the ECM so far ??
    And then......what line of work are you in ?
    Don't people PAY you for your training and experience and expertise ??
    Why do you think that is such a bad thing when it comes to car mechanics ???
  11. ChapmanF
    18,985
    That can't happen unless you post what your diagnostic codes are. If they're not the same as mine, we don't have the same issue.
    Even if they are the same, there's still a set of possible issues: the code narrows it down, then there's some actual troubleshooting on the car to be done to pin it down completely. So even two people with the same diagnostic codes may or may not have the same issue.
    But if the only information you can post is that your hey-read-the-codes lights are lighting up and the car is shutting off, there's no way for anybody to tell whether they are the someone you are looking for, or not.
    -Chap
  12. JerryMcG
    JerryMcG New Member
    Independence, MO
    I am looking into techstream and fault codes literally right now. Thanks for your help guys.
    SFO likes this.
