Questioning the Value of SGII
Discussion in 'Gen 3 Prius Accessories and Modifications' started by markabele, Jun 18, 2012.
  1. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    You can also log row 55 (set at 75 inside) and row 52 (about 85 outside). You may also consider row 51 (Room Temp Sensor) and row 57 (Adjusted Ambient Temp).
    Vincent
  2. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    So I have an issue with my slip indicator and its $125 just to have the dealer run a diagnostic test. If I got the trouble codes for them myself, will that save me $125?
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You can read and clear codes. With the codes you can lookup the error. That is about it though.
