Questions,Questions...
Discussion in 'Gen 2 Prius Main Forum' started by penbed, May 16, 2008.
  1. penbed
    penbed New Member
    222
    USA-Arkansas
    The display glass (plastic) on dash is not one solid pc. in my Prius.
    Where they fit together is uneven.
    Also there is a space along bottom along dash,dealer no help.
    Not the quality one would expect from Toyota.
    Is this normal,not the dealer,the plastic pc.
    Also when motor goes from one drive to another I feel a "shudder",
    sometimes more pronounced than others.
    Normal?
  2. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Normal, and normal.
    There's a split in the plastic on the speedo, and if you took apart your dash to see how it's constructed, you might be a tiny bit forgiving. It's not the greatest thing in the world, but not the worst either.
    The engine shudders a little when it stops sometimes. Usually for me it shudders more the first time on any given drive. I think the idea is that it's trying to stop with the crank in a specific position, and if it misses that position, it cranks around once more and tries to hit it again. Maybe when it's all the way warmed up it has an easier time stopping just right.
  3. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    I used to have some shuddering when the engine kicked on, in those 1st 7-10 seconds, but it oesn't happen any more.
    I offered myself 2 explanations:
    • Car was new (bought in Jan. 08) & was still in a self-sdjusting mode.
    • Cold winter weather was a shock to it's new systems.
    Hasn't occured in a couple of months, but if it comes up again next winter, I might blame it on something seasonal. (how about winter gas?)
  4. penbed
    penbed New Member
    222
    USA-Arkansas
    Thanks,
    Only had my Prius a few weeks.
    Maybe the shudder thing will go away soon.
    One more thing,my mpg is 49.5 avg. so far.
    Less than 1,000 miles-600 due to road trip-mostly freeway.
  5. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    No car is perfect. But the Prius *is* the number one selling car in the country right now for a reason.
    What it does for the Co2 levels from an auto and what it does for your gas relief is amazing and no one is close to it without being a complete battery only vehicle.
    The paint is not perfect. The seats are not perfect the speedo is not perfect. But overall the experience of owning and driving a car like this is liberating to say the least!
  6. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    Keep in mind, it being designed to minimize emissions and optimize fuel efficiency, the Prius is as light as economic tradeoffs allow. The items you notice, and other items you will eventually notice, are not a reflection of poor quality, but the result of purpose driven design.
  7. AltonGrey
    AltonGrey New Member
    Austin, Tx
    Something I noticed the other day. The bottom and top glove box don't line up all the way across. One gets wider the farther to the right it goes. Normal?
    EDIT: What I mean is the gap between the two gets a little larger towards the right. It almost looks like the top glove box isn't sitting straight. Minor, but I found it odd.
  8. penbed
    penbed New Member
    222
    USA-Arkansas
    Great!
    Now I am going to run out and check mine.
    Any other tidbits before I do so?
  9. Prius Prime
    Prius Prime Junior Member
    68
    Macomb, MI
    2016 Prius v wagon
    RE: the shudder--read the FAQ on the Five Stages of Prius Hybrid Operation- I think this is the link, if not you could do a search.
    http://priuschat.com/forums/kb.php?k=14&mode=articleThe shudder happens when you are at warm-up stage 2; after that the engine is warmed up enough and goes into stages 3 and 4 seamlessly.
    Now that the weather is warmer, it sure happens a lot earlier.
  10. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    Thanks for helpful tip ;)
  11. Ichabod
    1,794
    Newton, MA
    The Five Stages page is here.
  12. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    Got it -- thanks!
