Quick-Connect Charger Cord install
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Mendel Leisk, Feb 7, 2020.
  1. Mendel Leisk
    42,041
    I've had a CTEK quick-connect cord installed under the hood, for some time now. Popping the hood to access was a hassle, so I was looking for an exterior accessible place to route it.
    I spliced in 3' extra wire,wrapped it in plastic loom, and first ran it out through the upper grill:
    This worked, but I'm a little concerned: the plug is semi-sealed, but it is the positive and negative leads running back to the battery. If it were to get drenched, it might short out the battery. Also, it's a little funky, wedged through the grill.
    I was pretty much resigned to just coiling the extra length of cable up, having the plug back in the engine bay. Then came up with this:
    I found inserting a pen knife blade on the bias, around 9 o'clock, and giving a gentle pry, popped the cover off easily (clips are at 3 and 9 o'clock). Inside, everything was quite dry, even though the car was driven in heavy rain this morning.
    I ran the wire loom (from the fuse box area) over the driver's end of the front top beam (beside the block heater cord), Dremelled the black plastic trim cover piece underside ribs locally, so they're not riding up on the cord. If you take the hood retainer hook off it's a lot less torturous reaching an arm in there for fishing the wires through. There's a vertical interior baffle along the route, but you can just sneak a cord around it.
    Fed a few inches of conduit into the pocket, coiled it around, with the tip of the socket up near 10:30, just in case water does get in.
    I'll try it for a while, hopefully don't wear out the cover plate tabs. Replacement piece is $6.42 CDN here, fwiw:
    Genuine Toyota 52128-47030-B0 (5212847030B0) COVER, FRONT BUMPER HOLE, LH for Toyota Prius - Amayama
    Part number:
    52128-47030-B0
    (Left-Hand, in Classic Silver Metallic)
    Oh, if this location doesn't pan out, there's always behind the front license plate... Still, I think as-is might be a keeper.
    Addendum: just realized I'm in 4th gen. Have reported it, requested to be moved.
    #1 Mendel Leisk, Feb 7, 2020
    Greenteapri, Rebound and Grit like this.
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    That's a cool idea.
    Were you having battery charge issues?
  3. Mendel Leisk
    42,041
    We're low usage, the car often sits 2~4 days. Then it might be just a grocery run. I keep it connected to a charger as often as not.
  4. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Neat idea! Looks like something I would do. Ha!
  5. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Nice
    call that IN-GEN3-NEW-IT-BE
    You reserving the other side for the block heater? ;)
  6. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    Low usage just for grocery runs, reserved for a Prius? The good grocery stores must be hundreds of miles away!!!
  7. Mendel Leisk
    42,041
    My wife used to use it more for her work, but we're both retired now. Picture a drum solo that keeps going slower and slower. :)
    The Professor, Grit and dig4dirt like this.
