Quick flashing turn signals when unlocking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Claudia Valdivia Torres, Apr 10, 2018.
  1. Claudia Valdivia Torres
    oregon
    I recently just got a 2008 prius with 186k miles, I just had oil change, alignment plus new tires done and plan on changing the cabin filter pretty soon but my problem only right now is that when i unlock the car the blinkers quickly flash for a few sec then go away but if i’m locking the car nothing happens. don’t know what this could be? a fuse maybe?
  2. SFO
    SFO Senior Member
    5,297
    4,238
    Northern California
    How are you locking and unlocking your vehicle?
    49,801
    sould be one flash when locking/unlocking i think?
    WilDavis likes this.
  4. Claudia Valdivia Torres
    oregon
    i mostly use the keynob, and when i open the door that happens
  5. dolj
    dolj Senior Member
    7,791
    3,943
    Wellington, New Zealand
    One flash for lock; two flashes for unlock when using the key fob and also the SKS. Nothing if using the metal key. Using the metal key to unlock when locked via the SKS/key fob, will set off the alarm (if fitted).
    #5 dolj, Apr 12, 2018
  6. bisco
    49,801
    one if by land, two if by sea...
