Quick question??
Discussion in 'Generation 1 Prius Discussion' started by aswresm, Sep 21, 2015.
  1. aswresm
    aswresm Junior Member
    50
    2002 Prius
    I
    Any chance we can use a 14v auxiliary battery instead of a 12v battery in a Gen. 1 Prius??
    52,918
    who makes a 14 volt battery?
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Where will you get 14 vollt bulbs, wipers, fans, radios? What would charge a 14 volt battery if you found one?
    What are you hoping to solve with 14 volts?
    52,918
    13 volt angst?
  5. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Perhaps two extra volts are better than one? :cool:
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Don't really know why, but here it is.
    14 volt AGM Battery.
  7. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    I wonder if it's really 14V or just a regular 12V battery with more attractive labeling....like the Spinal Tap amp that goes to 11.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    XP1000CK1 - XS Power they seem to be sold with a A/C charger because nothing in the car can charge them.
    S Keith likes this.
  9. S Keith
    S Keith Senior Member
    799
    331
    AZ
    2003 Prius
    ^^This is why it's a bad idea. I assume they've added a 7th cell. If that's the case, the car can't keep it fully charged. Lead acid batteries are happiest fully charged. You'll be running around with it at ~85% charge shortening its life. It will actually be flat at ~12V.
    Bad idea all around. Throw the absurd cost on top of it, and it drops into the toilet, IMHO.
  10. dorunron
    3,318
    1,105
    Houston, TX
    I never said it was a good idea or practical. I simply pointed out there is such a animal. Vendor also claims to have a 16 volt battery. Supposedly these high power batteries are for vehicles that are sporting large amps for sound systems and so forth.
    I do agree that most on board charging systems will not charge the battery fully which will cause a short life span in the Prius.
  11. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    The charging converter on my gen 1 only puts out 13.6-13.7 volts. Most alternator driven charging systems max out at about 14.5. A 12v battery is 13.2v at a full charge, 6 cells @ 2.2v each. I imagine your 14 battery is fully charged at 15.4 volts.
