Quiz on Key Usage
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tonycd, Jan 12, 2018.
  1. tonycd
    tonycd Member
    84
    56
    Here's my quandary…
    I drop off my cars at a local independent mechanic for service. He's a family businessman who's willing to fix the car, lock it up and let me pick it up after hours.
    My problem is, before the era of radio-signalling smart key fobs, I could tell him to lock the keys in the car, then come after he closed with a second key, and pick up both key and car. But the fob system in the Prius, of course, is thoughtfully designed to keep you from locking your keys in your car, so you can't do so – even when you want to.
    My working hours completely overlap the garage's business hours. How do I get my key back without having the mechanic leave the Prius unlocked and completely vulnerable to theft by the first person who walks past it?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    One idea, lock car, remove battery from fob, close door. (if you lock the car with the button inside car door, you can remove battery any time.
  3. tonycd
    tonycd Member
    84
    56
    I sincerely appreciate the suggestion, Jimbo. But the problem I see with the suggestion is that then the mechanic can't start or drive the car to fix it.*
    (*In theory, he could reinstall the battery to do so and re-remove it afterward. But as a practical matter, that not only would do violence to the remote's internals, it would also be an awful lot of fussing to ask of the mechanic.)
  4. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    Wrap the remote in aluminum foil when you want to leave it in the car. Take the foil off when you want to use it again.
  5. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    Leave the key in the space behind the fuel cap door. Works better than foil.
  6. tonycd
    tonycd Member
    84
    56
    Wow, what great suggestions. Thanks very much.
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Place keyfob in car. Pull exterior door handle. Manually lock door. Close door with handle pulled.
    Raytheeagle likes this.
