R.I.P. iPod! Should I get a Touch?
Discussion in 'Fred's House of Pancakes' started by daniel, Jan 10, 2010.
  1. awmyhr
    awmyhr New Member
    16
    Raleigh, NC
    FWIW, music on the iTunes Music Store has been DRM-free for quite sometime now.
  2. awmyhr
    awmyhr New Member
    16
    Raleigh, NC
    I am surprised that Apple support indicated a need for more hardware, that doesn't sound right. You should be able to go into "System Preferences", select "Sharing", then click on "Internet Sharing" and configure (I'm using the latest Snow Leopard, things were a little different in earlier versions).
    I seldom have issues with button presses (or any other touch action) registering. If it happens system-wide (especially in the same spot in all apps), I'd have it looked at, if it is specific to one app then it may be just a matter of learning the 'hot spot.'
  3. brick
    brick Active Member
    1,083
    79
    Upstate NY
    If the OP defines quality as a shiny Apple logo then sure, the Sandisk won't have that. If the OP wants sound quality then the Sandisk is an excellent choice (as well as being a decent value). I have a 4GB Sansa Clip and it really is a great little music machine. This comes from someone with a very low tolerance for poor sound reproduction!
    **EDIT**
    I have the old version (2 years old) but for go-anywhere player this gets my vote:
    http://www.sandisk.com/products/san...ayers/sandisk-sansa-clipplus-mp3-player-.aspx
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    Which chess app did you end up with Daniel? I have CaissaPro and find it challenging and pretty easy to use.
  5. daniel
    14,487
    1,519
    Spokane, WA
    Note that I do not have a wireless network set up. I was essentially trying to use the Mac as a router, I guess: The Mac is connected to the cable model via an ethernet cable. I thought airport in the Mac would allow the Touch to connect to the internet through the Mac.
    I really know nothing at all about networking or wi-fi.
    I have a little Linksys wireless router, and once upon a time it was configured so the N800 could access the internet through it. But I have no idea how I managed to configure it, and it is presently re-set to its default settings, and nothing seems to be able to connect to it. I need a tech person to set it up again for me.
    However I really have no need to access the internet from the Touch at home. I just wanted to see if it would work, and play with it for a bit, and I did that by going to the library.
    I have iChess Lite, which cost 99 cents. I didn't realize that the search function only shows a few results until you click on "See All" so I thought there were only a few to choose from. Now I see oodles of them. There is a Caissa Chess, which gets very mixed reviews, but I don't see a Caissa Pro. I'm not sure how playing on the small screen will work out for me.
    Now I have gotten a Mahjong game, and added Audubon Flowers to Audubon Mammals (field guides). Not as good as the better books, but a lot smaller and lighter.
    Questions for the experts:
    Is there any way to change the order in which photos appear in a photo album?
    How do I create more than one album?
    Is there any way to change the order in which playlists appear? (other than naming them cleverly so the alphabetical order is the order I want.)
  6. daniel
    14,487
    1,519
    Spokane, WA
    I just bought Fritz Chess. Definitely one of the strongest chess programs out there.
  7. awmyhr
    awmyhr New Member
    16
    Raleigh, NC
    "Chess with Friends" (free) is great for playing against other people on the internet, "Deep Green" (not free) is a very strong, good looking chess program with a long pedigree (I believe the original version was written for Apple II). I've heard of Fritz before, may have to check it out. For solitaire, I recommend checking out "SolFree" by Solebon (free). It's good enough for me that I've never looked for another. If you like tower defense type games, check out TapDefense (free). "Amazing Sudoku Lite" by Dava (free) makes decent use of the available screen space.
    I haven't played much w/photo albums on the iPod itself, I actually just sync "last 20 events." Album creation and management is handled in iPhoto on the Mac. Use the photo tab in iTunes (when the iPod is connected) to manage which albums are synced. Same with playlists - best I can tell playlists are always listed alphabetically on the iPod.
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    daniel,
    DO NOT GIVE UP ON YOUR OLD I POD!!
    i have 4, and each one has "failed" on me. one was the most important as it was my 80?? GB pod that had about 500 albums, all painfully burned to my Mac, put on ipod then ERASED because they took up so much room.
    now, the reset process is one, i am very familiar with, so i did it, it did not work, but i also knew that it sometimes takes several tries, so i did it a FEW DOZEN TIMES over the period of a week or so. nothing.
    i was very depressed, shelved it. got another which was immediately commandeered to put kiddie music on. this was last year. now, occasionally, i plug it in, charge it, then do a few reset cycles... well, about 2 months ago...
    IT CAME BACK TO LIFE!!!
    so all i can say is, if there is stuff on it you cannot easily reproduce, keep it. mess with it when you have a few minutes.
    now i also have an i pod 4 GB mini. its 2 years older than the above i pod. it "fails" about once a week, but usually on takes 1-3 reset cycles to get it going. it has a battery life shorter than breath cycle of a good deep water diver so needs to be plugged in most of the time. this is the one i listen to daily in what ever car i am driving in.
  9. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ummm same thing happened to me, but only because i had moved my songs. the new install did not recognize the new location so did not import the catalog. now, this was about 3-4 years ago, but i just followed directions on apple support page to find the location (easy for me since mine was like 75 GB in size!!)
    there is also a program u have to buy, but pretty cheap, like $15-20... or so, that will scan your laptop and find it for you. i also have that and it works.
    now, the reason why i moved the directory, was after i got the extra i pod, i had also started a relationship and now had 3 pods which basically ran me out of disk space, so i took the biggest one's directory and moved it to a portable drive.
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    daniel, dont discount wi-fi... i can tell you with 100% certainty (without violating job NDA) that wi-fi will be playing a much much larger role in nearly everyone's lives.
    your sister's mobile broadband service is currently overpriced (my opinion) and has limited data transfer allowances that will all change dramatically in the next year.
  11. risingsun
    risingsun seeker of the way
    186
    30
    Prescott, AZ
  12. daniel
    14,487
    1,519
    Spokane, WA
    If you want STRONG play, Fritz is the choice. $7 and worth it.
    I got Sol Free and deleted it. It doesn't have the games I want.
    I "cheat" by making the machine show me the "possibles." But the Touch is just too small... too hard on my eyes.
    Thanks!!!
    Fooey.
    My 2 GB iPod held plenty for me, but not enough to care that I had to put it all on the Touch all over again. The battery is fine. And Re-set works. But no matter what I do, all I get is a trouble icon and the URL for support.
    I use wi-fi when I travel, to get email, check the weather, look stuff up, etc. The Touch is even lighter than the Nokia N800, and has a REAL browser (Safari).
    I just don't care to be "available" at every time and place. I like to check my email once a day. I turn my landline telephone off at night, or when taking a nap, and I never have my cell phone on except when I want to make a call. I never use IM and have no IM account. I don't text. I don't Tweet. I don't do social networking, beyond posting here.
    This morning I downloaded Doodle Jump, a free Blackjack, and the pay (99 cent) version of Jumbline because it allows unlimited time play, and I need LOTS of time to find about six words out of a possible 30.
  13. koa
    koa Active Member
    980
    45
    Hawaii
  14. SPEEDEAMON
    SPEEDEAMON Professional Car Nut
    1,556
    606
    Los Angeles
    Thanks Dave, What is the name of this program?
  15. daniel
    14,487
    1,519
    Spokane, WA
    I considered Skype for my Nokia N800, which has wi-fi and the necessary software, because I go places where there is internet and wi-fi but no phone service. But the internet connection at these places is usually slow; adequate for email and weather reports, but not for voip.
  16. royzaboy
    royzaboy Junior Member
    Grand Forks, ND
    Good point, but only since 2007 if you wanted to pay $1.29 per song, less than a year for the rest. If you have a huge library collected over several years, (I have well over 1000) it will be an issue. Not insurmountable, but an issue none the less.
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i have never spent a single cent at the itunes store
  18. dogfriend
    7,512
    1,189
    Carmichael, CA
    I'm telling Steve on you. :madgrin:
  19. awmyhr
    awmyhr New Member
    16
    Raleigh, NC
    That was my initial intention, as I prefer my music on bright, shiny discs. However at some point iTMS started offering exclusives and hard-to-finds that I found hard to resist. I still did not buy much until they started offering DRM-free. I think I still have a couple hundred DRM'd tracks, but most of those are freebie 'song of the week' tracks. I've also bought some videos to compare to DVD experience, and of course iPod touch apps (I will pay $$ for apps that I deem worthy, as they are very reasonably priced in comparison to other platforms, and there are some good ones out there).
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well one of these days i will buy something, but i am not much into newer music, i have about 6734 songs more or less. (actually that is count on the musipod. but videopod also has a few dozen along with talkiepod but havent really counted them and they are all free songs from itunes)
    now, i do take advantage of the free songs they issue weekly. have a bunch of them...one of the last ones was a song from Twilight...one of the few i liked. (my SO likes them and keeps downloading them)
    now, my SO has purchased some, but had purchased a bunch before we got together and i am sure she has probably gotten some since then, but she has her own little i pod and i havent a clue as to what is on it
